I want to use VBA to interpolate elevations from an existing surface object. I think that it should look like this:
elevation=oSurface.FindElevationAtXY(xi,yi)
When I run the code I get an error message at this line:
Set AeccApp = ThisDrawing.Application.GetInterfaceObject("AeccXUiLand.AeccApplication")
The error is "problem with loading application"
I have attached 2 jpg files, one showing the code and the error message, the other showing the references that I selected. I am running C3D 2016 on Windows 7 Professional 64 bit
Thank you
John
Solved by hippe013. Go to Solution.
Solved by OceanaPolynom. Go to Solution.
Thanks for your help. There doesn't seem to be anything else That I can add. I have attached a third jpg (Unmarked References.jpg) that shows the relevant area of the References window.
Thank you
John
