Hi! I have created a custom ditch assembly. I have used auxiliary points to test different slopes and then check their existence with IsValid API function. Depending on whether these auxiliary points exist or not I choose different geometry for the ditch. There are always some auxiliary points that do not exist in any given section and I would like subassembly composer not to report it as an error. Is it possible? As it is now all the auxiliary points that are not valid are reported as an error in the Event Viewer in Civil3D (see attached image). Thanks in advance!
