Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Do I have to append TIN Surface to the database?
3 REPLIES 3
heyimsp12
246 Views, 3 Replies
I'm trying to create a TIN Surface in the below function and later I want to extrude it into a solid of depth 2 meters.
While debugging the code, I have noticed that my code runs fine butt I still can't see new surfaces being created on C3D Document. Do I have to append the surface to the Model Space and then also add it to the transaction? If yes, i tried doing that as well but then I am getting error - Object already in database.
Here is my code:
 //Create TIN Surface and define its Breaklines and Boundaries.
        public ObjectId CreateTinSurface(Polyline2d boundary, bool ExtrudeSolid = false, double DepthOfSolid = 2.0)
            var surfaceId = new ObjectId(); //Placeholder for surfaceId.
            using (var db = Application.DocumentManager.MdiActiveDocument.Database)
            using (var trans = db.TransactionManager.StartTransaction())
            using (var blockTable = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForRead))
            using (var modelSpace = (BlockTableRecord)trans.GetObject(blockTable[BlockTableRecord.ModelSpace], OpenMode.ForRead))
                try
                    //Create an empty TIN surface
                    surfaceId = TinSurface.Create(db, "TempVisSurface_"+boundary.BlockName.Trim().ToString());
                    //Open the TIN surface
                    TinSurface surface = (TinSurface)trans.GetObject(surfaceId, OpenMode.ForWrite);
                    //Surface Breaklines Definition
                    //BoundarySet will also serve as a BreaklinesSet here, since the surface is empty anyways.
                    ObjectIdCollection breaklineSet = new ObjectIdCollection();
                    breaklineSet.Add(boundary.ObjectId);
                    surface.BreaklinesDefinition.AddStandardBreaklines(breaklineSet, 1.0, 1.0, 1.0, 0);
                    ////Surface Boundary Definition
                    ObjectIdCollection boundaryIdSet = new ObjectIdCollection();
                    boundaryIdSet.Add(boundary.ObjectId);
                    surface.BoundariesDefinition.AddBoundaries(boundaryIdSet, 1.0, Autodesk.Civil.SurfaceBoundaryType.Outer, true);
                    //Conditionally also convert the surface into solid with given depth
                    //Ideally, Solid will be created with depth 2m.
                    if (ExtrudeSolid == true)
                        surface.CreateSolidsAtDepth(DepthOfSolid, surface.Layer, 0);
                    //***My question is: do i need to run the below code??
                    //modelSpace.AppendEntity(surface);
                    //trans.AddNewlyCreatedDBObject(surface, true);
                    //***End of question
                catch (Exception ex)
                    Application.ShowAlertDialog("Error creating TIN Surface.\n" + ex.Message);
            return surfaceId;
Labels (1)
3 REPLIES 3
hosneyalaa
in reply to: heyimsp12
HI @heyimsp12
Think
YOU Forgot this to the code
trans.Commit();
heyimsp12
in reply to: hosneyalaa
Thanks @hosneyalaa. I will end the transaction, but that still doesn't solve the problem.
Also btw, since the transaction is in using-statement, I don't think I necessarily need to close it but I'm not sure. It sounds like a good idea to commit the transaction manually.
Jeff_M
C3D handles adding the Surface to the database.
If you don't Commit the transaction, it is disposed when exiting the Using statement.
I think you will need to Rebuild the Surface prior to creating the solids.
Jeff_M, also a frequent Swamper
Rail Community
