Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Create offset alignment using start and end station
3 REPLIES 3
adcdao
606 Views, 3 Replies
I'm trying to offset an alignment but by segment. I'm able to offset all the alignment but not by segment. I found this method:
public static ObjectId CreateOffsetAlignment(
	Database database,
	string alignmentName,
	string parentAlignmentName,
	double offset,
	string styleName,
	double startStation,
	double endStation
But I didn't find any example of how to use that. I don't know how to get startStation and endStation of each segment of an alignment.
Thank you for your help,
André
3 REPLIES 3
adcdao
in reply to: adcdao
I think I found the solution myself. I was inspired by this link:
https://forums.autodesk.com/t5/civil-3d-customization/alignment-pi-and-or-tangent-intersections/td-p...
So here's my solution using an array of existing lines:
ObjectId AlignmentID = Alignment.Create(C3Ddoc, AlignmentName, "", AlignmentLayer, AlignmentStyleName,
AlignmentLabelSetStyleName);
Alignment align = acTrans.GetObject(AlignmentID, OpenMode.ForWrite) as Alignment;
foreach (Line aLine in acLinesList)
align.Entities.AddFixedLine(aLine.StartPoint, aLine.EndPoint);
Station[] sta = align.GetStationSet(StationTypes.All);
long staCounter = 0;
while (staCounter < sta.Count()-1)
//Offset creation by segment
Alignment.CreateOffsetAlignment(acCurDb, AlignmentName + " - Right (" + (staCounter + 1).ToString() + ")",
AlignmentName, AlignmentOffset, AlignmentStyleName, sta[staCounter].RawStation, sta[staCounter+1].RawStation);
Alignment.CreateOffsetAlignment(acCurDb, AlignmentName + " - Left (" + (staCounter + 1).ToString() + ")",
AlignmentName, AlignmentOffset * -1, AlignmentStyleName, sta[staCounter].RawStation, sta[staCounter+1].RawStation);
staCounter += 1;
It seems to do the job like I want.
Hope this code snippet can help someone else.
André
Jeff_M
in reply to: adcdao
This will give you all the start/end stations of the segments. The variable aln has been set already as teh ALignment object.
                                List<double[]> stationsList = new List<double[]>();
                                foreach (Autodesk.Civil.DatabaseServices.AlignmentEntity aEnt in aln.Entities)
                                    for(int i = 0; i< aEnt.SubEntityCount;i++)
                                        var startSta = aEnt[i].StartStation;
                                        var endSta = aEnt[i].EndStation;
                                        stationsList.Add(new double[] { startSta, endSta });
Jeff_M, also a frequent Swamper
adcdao
in reply to: Jeff_M
Thank you Jeff for this clarification, I think your solution is better than mine.
André
Rail Community
