Convert multiple lwpolylines into multiple alignments
treforfjones
treforfjones
Hi can anyone assist with the code in blue below
The code reports polyline id and alignment name for the alignment creation
but fails to create any alignment either empty with out geometry, the indented plops options
or any error reports
cheers
for any pointers
Trefor
Option Explicit On
Option Strict Off
Imports System
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.Civil.DatabaseServices.Styles
Imports Autodesk.Civil.ApplicationServices
<Assembly: CommandClass(GetType(Halign))>
<Assembly: ExtensionApplication(GetType(Halign))>
Public Class Halign
    Implements Autodesk.AutoCAD.Runtime.IExtensionApplication
    Private m_doc As CivilDocument = Nothing
    Private m_trans As Transaction = Nothing
    Private m_Database As Database = Nothing
    Private m_Editor As Editor = Nothing
    Private m_AlignmentLabelStyleSetId As ObjectId = ObjectId.Null
    Private m_AligmentStyleId As ObjectId = ObjectId.Null
    Private m_SiteId As ObjectId = ObjectId.Null
    Private m_Alignment As Alignment = Nothing
    ''' <summary>
    ''' Implement Initialize of IExtensionApplication
    ''' </summary>
    ''' <remarks></remarks>
    Sub Initialize() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Initialize
    End Sub
    Sub Terminate() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Terminate
    End Sub
    <CommandMethod("halign")>
    Public Sub halign()
        '' Get the current document and database
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        Dim docCol As Autodesk.AutoCAD.ApplicationServices.DocumentCollection = Application.DocumentManager
        m_Database = docCol.MdiActiveDocument.Database
        m_Editor = docCol.MdiActiveDocument.Editor
        m_doc = Autodesk.Civil.ApplicationServices.CivilApplication.ActiveDocument()
        '' Start a transaction
        Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
            '' Open the Block table for read
            Dim acBlkTbl As BlockTable
            acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
            '' Open the Block table record Model space for read
            Dim acBlkTblRec As BlockTableRecord
            acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace),
                                        OpenMode.ForRead)
            '' Step through the Block table record
            For Each acObjId As ObjectId In acBlkTblRec
                If (acObjId.ObjectClass.DxfName = "LWPOLYLINE") Then
                    ed.WriteMessage(vbLf & acObjId.ToString)
                    Dim acount As Integer
                    acount += 1
                    Dim Alignmentlabel As String = "A"
                    Dim AlignmentName = Alignmentlabel & acount
                    ed.WriteMessage(vbLf & AlignmentName)
                    ''Dim plops As Autodesk.Civil.DatabaseServices.PolylineOptions
                    ''plops.AddCurvesBetweenTangents = False
                    ''plops.EraseExistingEntities = True
                    ''plops.PlineId = acObjId
                    Dim alignId As ObjectId = Nothing
                    alignId = Alignment.Create(m_doc, AlignmentName, "Site 1", "alignments", "Basic", "Basic")
                End If
            Next
            '' Dispose of the transaction
        End Using
    End Sub
End Class
Replies (28)
Jeff_M
At first glance I would say that you are disposing the transaction...if you want the additions saved, you must Commit the transcation. Also, please use the code button (the one that looks like </> ) when inserting code to your posts.
                End If
            Next
            '' Dispose of the transaction ***** NO!
            acTrans.Commit ''Do this in order for your additions/edits to be saved
        End Using
    End Sub
treforfjones
Hi Jeff
Thanks for that pointer.
The mist rose briefly.
Had to go back to work.
I'm now in the process of reviewing my code
Will get back to you and the other folks who contribute
cheers
Trefor
treforfjones
Hi Jeff,
I still having problems with "transaction"
My code successfully extracts the polylines ids from the AutoCAD database
and creates an alignment name. The code also seems to access the civil 3d database
and reports empty alignments being created (note showing in Prospector).
My intention is to create an alignment from each polyline
Many thanks to you or anyone who can help
cheers
Trefor
Imports System
Public Class Halignvalign
    End Sub
    End Sub
    <CommandMethod("Halign")>
    Public Sub AlignmentsByLWPolylineCreation()
                                        OpenMode.ForRead)
                    acount += 1
                    Dim m_Database = docCol.MdiActiveDocument.Database
                    Dim m_Editor = docCol.MdiActiveDocument.Editor
                    Dim m_doc As Autodesk.Civil.ApplicationServices.CivilDocument
                    Dim AlignIds As ObjectIdCollection = m_doc.GetAlignmentIds
                    For Each alignId As ObjectId In AlignIds
                        m_Editor.WriteMessage(vbLf & alignId.ToString)
                    Next
                    Using m_trans As Transaction = m_Database.TransactionManager.StartTransaction()
                        Try
                            Dim oAlignmentId As ObjectId = Alignment.Create(m_doc, AlignmentName, "", "alignments", "Basic", "Basic")
                        Catch ex As System.Exception
                            m_Editor.WriteMessage(vbLf & "Error when creating alignment")
                        End Try
                        m_trans.Commit()
                    End Using
                End If
            Next
        End Using
    End Sub
End Class
try this method
C#代码片段:
            plineOptions = new PolylineOptions();
            plineOptions.AddCurvesBetweenTangents = civilDoc.Settings.GetSettings<SettingsCmdCreateAlignmentEntities>().CreateFromEntities.AddCurveBetweenTangents.Value;
            plineOptions.EraseExistingEntities = civilDoc.Settings.GetSettings<SettingsCmdCreateAlignmentEntities>().CreateFromEntities.EraseExistingEntities.Value;
foreach (ObjectId id in plIds) { alignmentName = Alignment.GetNextUniqueName(civilDoc.Settings.GetSettings<SettingsCmdCreateAlignmentEntities>().DefaultNameFormat.AlignmentNameTemplate.Value); plineOptions.PlineId = id; try { Alignment.Create(civilDoc, plineOptions, alignmentName, null, layerName, styleName, labelSetName); } catch (System.Exception ex) { ed.WriteMessage("\n"+ex.Message); } }
王磊
您认为此帖子是否有用?欢迎为此帖点赞。
您的问题是否已得到解答?请点击“接受解答”按钮。
treforfjones
Thanks for your reply
I have extracted your snippet for poptions.
In dwgs with out preloaded style sets m_Editor.WriteMessage(vbLf & acObjId.ToString) reports as expected
In dwgs with  preloaded style sets m_Editor.WriteMessage(vbLf & acObjId.ToString) reports polyline id and
alignment name and finishes cleanly without creating any alignments.
many thanks for any pointers
Trefor
                    Dim poptions As Autodesk.Civil.DatabaseServices.PolylineOptions
                    poptions.AddCurvesBetweenTangents = False
                    poptions.EraseExistingEntities = True
                    poptions.PlineId = acObjId
                        Try
                            Dim AlignId As ObjectId = Nothing
                            AlignId = Alignment.Create(m_doc, poptions, AlignmentName, "", "alignments", "Basic", "Basic")
                            m_trans.Commit()
                            m_trans.Dispose()
                        End Try
                    End Using
                        Try
                        End Try
                             m_trans.Commit()
                            m_trans.Dispose()
                    End Using
王磊
您认为此帖子是否有用?欢迎为此帖点赞。
treforfjones
Thanks for that
It brightened up my day and gave me something else to consider.
Unfortunately it still doesn't create any alignments
many thanks
Trefor
lu_an_jie
1. Basic structure of transactions:
                           Dim trans As Transaction = dwg.TransactionManager.StartTransaction()
                            Try
'your code here .... . trans.Commit() Catch ex As Exception ' ok so we have an exception ed.WriteMessage("problem due to " + ex.Message) Finally ' all done, whether an error on not - dispose the transaction. trans.Dispose() End Try
2. You need to pass null for the SiteName
3. You did not validated the existence of the StyleName, LayerName and LabelSetName. For testing I would rather use the first of them in the specific collections, than change to specific one and check if the present.
Regards
Andreas Luka (Lu An Jie)
http://www.luka-consult.de
Creator of the LX-Stair App for Civil 3D
Jeff_M
Trefor, you are not committing the acTrans Transaction, therefor everything within it is disposed. Why are you using 2 transactions? The m_trans is not needed.
lu_an_jie
Here is a working code in C#
// (C) Copyright 2018 by
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.Civil;
using Autodesk.Civil.ApplicationServices;
using Autodesk.Civil.DatabaseServices;
using Autodesk.Civil.Settings;
// This line is not mandatory, but improves loading performances
[assembly: CommandClass(typeof(ALC_AlignmentFrpmPolyLine.MyCommands))]
namespace ALC_AlignmentFrpmPolyLine
    public class MyCommands
        // Modal Command with pickfirst selection
        [CommandMethod("MyAlignmentFromPolyline", CommandFlags.Modal | CommandFlags.UsePickSet)]
        public void MyPickFirst() // This method can have any name
            // Get the current document and database
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            CivilDocument civdoc = CivilApplication.ActiveDocument;
            // Build a filter list so that only olyline are selected
            TypedValue[] listTV = new TypedValue[1] { new TypedValue((int)DxfCode.Start, "LWPOLYLINE") };
            SelectionFilter filter = new SelectionFilter(listTV);
            PromptSelectionOptions pso = new PromptSelectionOptions();
            pso.MessageForAdding = "Select polylines: ";
            // Get a selection
            PromptSelectionResult result = ed.GetSelection(pso, filter);
            if (result.Status == PromptStatus.OK)
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    try
                        // get id of Layer
                        ObjectId idLayer = db.Clayer;
                        LayerTable lt = tr.GetObject(db.LayerTableId, OpenMode.ForRead) as LayerTable;
                        if (lt.Has("alignments")) idLayer = (lt["alignments"]);
                        // get objectid  of the 1st Alignment style or Basic
                        ObjectId idStyle = civdoc.Styles.AlignmentStyles[0];
                        if (civdoc.Styles.AlignmentStyles.Contains("Basic")) idStyle = civdoc.Styles.AlignmentStyles["Basic"];
                        // get objectid of the 1st AlignmentLabelSetStyle or Basic
                        ObjectId idLabelSet = civdoc.Styles.LabelSetStyles.AlignmentLabelSetStyles[0];
                        if (civdoc.Styles.LabelSetStyles.AlignmentLabelSetStyles.Contains("Basic")) idLabelSet = civdoc.Styles.LabelSetStyles.AlignmentLabelSetStyles["Basic"];
                        // step through the objects in the selection set
                        SelectionSet ss = result.Value;
                        foreach (SelectedObject sob in ss)
                            // check list is not empty & object is from the expected type
                            if (sob != null && sob.ObjectId.ObjectClass.DxfName == "LWPOLYLINE")
                                // set options
                                PolylineOptions plos = new PolylineOptions();
                                plos.AddCurvesBetweenTangents = true;
                                plos.EraseExistingEntities = true;
                                plos.PlineId = sob.ObjectId;
                                // create unique name
                                String nAlign = Alignment.GetNextUniqueName(civdoc.Settings.GetSettings<SettingsCmdCreateAlignmentEntities>().DefaultNameFormat.AlignmentNameTemplate.Value);
                                // create alignment
                                ObjectId idAlign = Alignment.Create(civdoc, plos, nAlign, ObjectId.Null, idLayer, idStyle, idLabelSet);
                                ed.WriteMessage("\nAlignment created with id: {0}", idAlign);
                        // Save the new objects to the database
                        tr.Commit();
                    catch (Autodesk.AutoCAD.Runtime.Exception ex)
                        ed.WriteMessage("/n Exception message :" + ex.Message);
            else
                ed.WriteMessage("No Polylines selected");
Regards
lu_an_jie
and VB
' (C) Copyright 2011 by
Imports System
Imports Autodesk.Civil.Settings
' This line is not mandatory, but improves loading performances
<Assembly: CommandClass(GetType(ALC_VB_AlignmentFromPolyline.MyCommands))>
Namespace ALC_VB_AlignmentFromPolyline
    Public Class MyCommands
        ' Modal Command with pickfirst selection
        <CommandMethod("MyAlignmentFromPolyline", CommandFlags.Modal + CommandFlags.UsePickSet)>
        Public Sub MyPickFirst()
            'Get the current document And database
            Dim civdoc As CivilDocument = CivilApplication.ActiveDocument
            'Build a filter list so that only olyline are selected
            Dim arTV(0) As TypedValue
            arTV.SetValue(New TypedValue(DxfCode.Start, "LWPOLYLINE"), 0)
            Dim filter As SelectionFilter = New SelectionFilter(arTV)
            Dim pso As PromptSelectionOptions = New PromptSelectionOptions()
            pso.MessageForAdding = "Select polylines"
            'Get a selection
            Dim result As PromptSelectionResult = ed.GetSelection(pso, filter)
            If (result.Status = PromptStatus.OK And Not IsDBNull(result.Value)) Then
                ed.WriteMessage(vbCrLf + "Valid selection")
                Dim tr As Transaction = db.TransactionManager.StartTransaction()
                Try
                    'get id of Layer
                    Dim idLayer As ObjectId = db.Clayer
                    Dim lt As LayerTable = tr.GetObject(db.LayerTableId, OpenMode.ForRead)
                    If (lt.Has("alignments")) Then idLayer = lt("alignments")
                    'get objectid  of the 1st Alignment style Or Basic
                    Dim idStyle As ObjectId = civdoc.Styles.AlignmentStyles(0)
                    If (civdoc.Styles.AlignmentStyles.Contains("Basic")) Then idStyle = civdoc.Styles.AlignmentStyles("Basic")
                    'get objectid of the 1st AlignmentLabelSetStyle Or Basic
                    Dim idLabelSet As ObjectId = civdoc.Styles.LabelSetStyles.AlignmentLabelSetStyles(0)
                    If (civdoc.Styles.LabelSetStyles.AlignmentLabelSetStyles.Contains("Basic")) Then idLabelSet = civdoc.Styles.LabelSetStyles.AlignmentLabelSetStyles("Basic")
                    'step through the objects in the selection set
                    Dim ss As SelectionSet = result.Value
                    For Each sob As SelectedObject In ss
                        'check is object Is from the expected type
                        If (sob.ObjectId.ObjectClass.DxfName = "LWPOLYLINE") Then
                            ' set options
                            Dim plos As PolylineOptions = New PolylineOptions()
                            plos.AddCurvesBetweenTangents = True
                            plos.EraseExistingEntities = True
                            'create unique name
                            Dim sccae As SettingsCmdCreateAlignmentEntities = civdoc.Settings.GetSettings(Of SettingsCmdCreateAlignmentEntities)()
                            Dim nAlign As String = Alignment.GetNextUniqueName(sccae.DefaultNameFormat.AlignmentNameTemplate.Value)
                            ed.WriteMessage(vbCrLf + nAlign)
                            'create alignment
                            Dim idAlign As ObjectId = Alignment.Create(civdoc, plos, nAlign, ObjectId.Null, idLayer, idStyle, idLabelSet)
                        End If
                    Next
                    tr.Commit()
                Catch ex As Autodesk.AutoCAD.Runtime.Exception
                Finally
                    tr.Dispose()
                End Try
            Else
            End If
        End Sub
    End Class
End Namespace
.Net
Regards
treforfjones
Many thanks for all your help and an excellent template
Can't thank you enough
cheers
Trefor
Joe_Wainwright
Thanks a lot for providing that, works perfectly. I would like to try and get it to name the alignment as the original layer name of the selected objects if possible? just struggling to get the layer name as a String.
Joe
Joe_Wainwright
I am new to coding in general but this is what i have got so far for having the Alignments named as per the Polyline Layer. I am getting an exception 'Specified cast is not valid'. Any help with this would be much appreciated.
Imports System
Imports Entity = Autodesk.AutoCAD.DatabaseServices.Entity
            'Get a selection
                Try
                    'get id of Layer
                    For Each obj As ObjectId In ss
                        Dim ent As Entity = CType(tr.GetObject(obj, OpenMode.ForRead), Entity)
                        'check object is from the expected type
                        If TypeOf ent Is Polyline Then
                            ' set options
                            plos.AddCurvesBetweenTangents = False
                            plos.PlineId = obj
                            'Get layer
                            Dim nLayer As String = ent.Layer().ToString
                            'create unique name
                            ed.WriteMessage(vbCrLf + nLayer)
                            'create alignment
                            Dim idAlign As ObjectId = Alignment.Create(civdoc, plos, nLayer, ObjectId.Null, idLayer, idStyle, idLabelSet)
                        End If
                    Next
                    tr.Commit()
                Finally
                    tr.Dispose()
                End Try
            Else
            End If
        End Sub
    End Class
End Namespace
Cheers
Joe
Jeff_M
I don't use VB much, but I think this line:
only needs to be this:
Also, the check if the entity is a Polyline is not needed since your selection set filter already insures that the only objects selected are polylines.
lu_an_jie
Jeff pointed already  you mistake:
the Layer Property of an entity is already a string, no need to convert.
What happens it that Layer() gives you an empty layer object, as this works as constructor in VB,
The call for a conversation would be: value.ToString().
Regards
Joe_Wainwright
Thanks for your help. I have tried that and still get the same error 'Specified Cast is Not Valid'. i think it may be to with these lines...
Is it because i am trying to get the ObjectID's from a SelectionSet?
Cheers
Joe
lu_an_jie
                    For Each obj As SelectedObject In ss
                        Dim ent As Entity = CType(tr.GetObject(obj.objectId, OpenMode.ForRead), Entity)
The result.Value is a list of type: SelectedObject
Regards
Joe_Wainwright
Thanks for your help, like i said im pretty new to this.
I wonder then, if it needs to be a SelectedObject, how can i get the layer property from each of the SelectedObjects? can i retrieve entities of the selected objects?
Cheers
Joe
