Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Civil3D 2013 COGO Point update User defined property value using C#
5 REPLIES 5
1590 Views, 5 Replies
Hello All,
 I need to update the user defined property values using C# code,
I can see information on how to ge the values of UDP but cannot see any information on how to modify, edit, udpate or add infromation to the UDP of a point.
Basically in the attached image i want to add "Street light" to the Type UDP.
Please advice
5 REPLIES 5
Jeff_M
If this doesn't help, show code you are trying.
cogopt.SetUDPValue(udpname, udpvalue);
Jeff_M, also a frequent Swamper
Hi Raghulan,
You can use CogoPoint.SetUDPValue
You can see some related code snippet in ADN IM DevBlog -
http://adndevblog.typepad.com/infrastructure/2012/08/set-parcel-userdefined-property-from-api.html
http://adndevblog.typepad.com/infrastructure/2013/04/civil-3d-net-api-cogo-point-how-to-read-a-user-...
Let me know if you have an issue using CogoPoint.SetUDPValue() API Hope this helps !
Cheers,
Partha
in reply to: Jeff_M
Thanks Jeff, will try and update!
Thanks Partha, Will try and update.
Here is the code to help someone else
public static void udpate_UDP(CogoPoint cogoPoint, string udp_classification, string ud_prop, string value)
            try
                UDPClassification udp_class = set_udp_class(udp_classification);
                if (udp_class != null)
                    UDPString udp_string = null;
                    Global.variables.ed.WriteMessage("\nClassfication: " + udp_class.Name);
                    foreach (UDP udp in udp_class.UDPs)
                        if (udp.Name == ud_prop)
                            //UDPString udp_string =
                            //udp_string = udp.Name;
                            udp_string = (UDPString)udp;
                            cogoPoint.SetUDPValue(udp_string, value);
                else
                    Global.variables.ed.WriteMessage("\nClassfication NOt found or incorrect: " + udp_classification);
            catch (Autodesk.AutoCAD.Runtime.Exception ex)
                Global.variables.ed.WriteMessage("\nError : " + ex.Message);
 public static UDPClassification set_udp_class(string udp_class_set)
            UDPClassification udp_class1 = null;
            try
                if (Global.variables.cdoc.PointUDPClassifications.Contains(udp_class_set))
                    foreach (UDPClassification udp_class in Global.variables.cdoc.PointUDPClassifications)
                        if (udp_class.Name == udp_class_set)
                            udp_class1 = udp_class;
                else
                    Global.variables.ed.WriteMessage("\nUDP Classification Dont exists! ", udp_class_set);
                    udp_class1 = null;
            return udp_class1;
Rail Community
