Announcements
Change Feature Line Style in LISP
This has got to be something simple, but I can't get my head around it.  I want to take a feature line that has been created by the "stepped offset" command and change its style, in LISP, of course.  I have the entity name and have dumped the object, but the style of the FL is not one of them. It shows up in the properties box, but how do I get to it to change it??
Dave
Replies (13)
I don't see 'Style' is exposed for AeccLandFeatureLine COM object.
Without digging it further, I doubt we can access the style.
How about a "simple" .NET routine that could be called by LISP? I have used a couple of those types of routines for other tasks.
Dave
Hi Dave -
Using .NET API you should be able to do this.
Check this -
FeatureLine.StyleName -> Gets or sets the Featureline's style name.
Hope this helps.
Partha Sarkar
Partha, thank you.  Yes I tracked this down yesterday also.  Now I am trying to get it working.  I have the Feature Line object and I think I need to get the StyleId to get to the StyleName property.  I am working in C#, but I am an extreme novice.   Any help would be appreciated.
Dave
Partha, (or anyone), my ignorance of C# will show below.  I am trying to change the style of a feature line.  O have a LSIP routine that will call this C# routine.  The inputs are the Feature Line Object Name and the Style to change it to.  I have not figured out the correct program lines.  Here is what I have.  Any help would be arrpeciated.
Here is the LISP code to call the C# routine.
(defun C:ChangeStyle ()
  (Setq FLLine (car (entsel "\nSlect Featrue Line to change style: ")))
  (setq FLObject (vlax-ename->vla-object FLLine))
  (setq newstyle "Curb")
  (FLStyleSetLisp FLObject newstyle)
 And here is the C# code that I have so far that obviously does not work.
namespace FLStyleOverride
    public class FLStyleOverride
       [LispFunction("FLStyleSetLisp")]
        public ResultBuffer cfunctionFLStyleSet(ResultBuffer rbfArgs)
            try
                Database db = Application.DocumentManager.MdiActiveDocument.Database;
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    //Get the arguments passed in...
                    Array arInputArgs = null;
                    arInputArgs = rbfArgs.AsArray();
                    ObjectId objId = (ObjectId)((TypedValue)arInputArgs.GetValue(0)).Value;
                    String Newstyle = (String) ((TypedValue)arInputArgs.GetValue(1)).Value;
                    Object NewStyleId = objId.GetObject(OpenMode.ForWrite);
                    String StyleName = Newstyle;
                    ResultBuffer rbfResult = default(ResultBuffer);
                    rbfResult = new ResultBuffer(new TypedValue(Convert.ToInt32(5005), "ProbableSuccess"));
                    tr.Commit();
                    return rbfResult;
            catch
                ResultBuffer rbfBadResult = new ResultBuffer(new TypedValue((short)LispDataType.Nil));
                //ResultBuffer rbfBadResult = String Newstyle;
                return rbfBadResult;
 Dave
Jeff_M
First week of elk hunting was hot & dusty. Didn't see a thing. Week 2 starts Saturday in Washington with my son, already snowing where we are headed in the morning. Should have better chances.
Now, here's what worked for me. First the lisp, then the c# code:
  (FLStyleSetLisp (vlax-get FLObject 'Handle) newstyle)
            try
                    TypedValue tv = (TypedValue)arInputArgs.GetValue(0);
                    ObjectId objId = db.GetObjectId(false, new Handle(Int64.Parse((string)tv.Value, System.Globalization.NumberStyles.AllowHexSpecifier)), 0);
                    string Newstyle = (string)((TypedValue)arInputArgs.GetValue(1)).Value;
                    FeatureLine fl = (FeatureLine)objId.GetObject(OpenMode.ForWrite);
                    fl.StyleName = Newstyle;
                    tr.Commit();
                    return rbfResult;
            catch
Jeff_M, also a frequent Swamper
Jeff, better luck this week.  I copied the code in and I am getting the same error I was getting earlier.  It is not recognizing the FeatureLine Object.  I get the following error.
Error 1 The type or namespace name 'FeatureLine' could not be found (are you missing a using directive or an assembly reference?)
I looked at the API reference and it showed the Assembly AeccDbMgd as Version 10.0.1111.0, my version is 9.0.2566.0.  I am in C3d 2012.  Could this be the problem??  This is the header info.
using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.EditorInput; using Autodesk.AutoCAD.Runtime; using Autodesk.Civil.DatabaseServices; using Autodesk.Civil.DatabaseServices.Styles; using System;
And here are the references.
undefined
I plan on retiring in a little less than 2 years.  There is no way I will learn enough .NET to make it worth while.  I think I will just keep on stumbling along with LISP.
Thanks again for your help.
Dave
Jeff_M
Make sure your usings are like so for the code I posted:(I should have shown this):
using System;
using Autodesk.Civil.Land.DatabaseServices; //(for 2013+ omit the Land.)
Jeff, adding the .Land.DataBaseServices fixed it.  Once more, thank you.  Also, just another reason I won't be spending a lot of time on .NET.  WAY to involved.  I guess I'm just too old to learn new tricks.
Dave
Dave -
Using .NET its just one line of code to change FeatureLine style 🙂
Check this -
http://adndevblog.typepad.com/infrastructure/2013/11/civil-3d-featureline-labeling-and-style-changin...
Cheers,
Partha
Thank you, Partha.  I expect I will be playing more with .NET.  I will be adding this site you referenced to my favorites.
Dave
hi,
How can i change Line Styles for Detail Lines using API not UI ?
i cant find any function can set the line style for any detail line using API
Hi Guys,
I don't have a great understanding of all the coding that you do, but i have an idea that I'm putting out there to see if it is possible.
I would like to have an .dwg file with a bunch of layers sitting in it, and i would like to be able to create a feature line style from each of these layers. The idea is that it would grab the layer name, colour, lineweight, linetype.. Essentially it would just convert a layer into a Feature Line style.
I understand that i could go in and manually create feature line styles and assign the layer to each of them but that is quite time consuming and each of my clients have different drafting and design standards.
Nick
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
