Is it possible to customize the coordinate style of the reference system template?
At,
Desenhista de Projetos em BIM
Engenharia Loading...
• Civil 3d • Revit • Infraworks • Dynamo • Excel
Gabriel Rafael | LinkedIn
Solved by Jeff_M. Go to Solution.
I only know that in drawing settings units and zone, we can change coordinate system. you can try to save as drawing with coordinate system as dwt, maybe it will work ?
If I understood your answer correctly... yes, that works. In fact, you don't even need to do that because I can already adjust the style directly where the coordinate grid was inserted.
The question is whether it is possible to customize the grid style. For example, display 3 decimal places instead of 4, add the prefix "N=", and other similar customizations.
At,
At,
