Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Background Mask Lisp
8 REPLIES 8
Message 1 of 9
sam.cutbirth
2335 Views, 8 Replies
Does anyone happen to have, or know where I can get started with a lisp routine that will apply or remove from a selection of text objects (or MLeaders), a background mask set to standard 1.5 coverage; fill color set to background???
Thank you, in advance!
Sam Cutbirth
8 REPLIES 8
Message 2 of 9
stacy.dunn
in reply to: sam.cutbirth
This will do most of what you need and works on mtext and mleaders.  It will not set the widht of the offset.
Stacy Dunn
Message 3 of 9
sam.cutbirth
Stacy, thank you so much!
Have a great day 🙂
Message 4 of 9
bfalconr2
in reply to: stacy.dunn
Thank you very much, it's just helpful,
Do you have one for dimensions?
Bruno
Message 5 of 9
sam.cutbirth
in reply to: bfalconr2
Bruno, I am still using the same snippet of lisp from the original post!  I never desired to account for dimensions but I can see that being a nice feature.., maybe someone can help with a modification.  If so, please post it here if you don't mind.
Best,
Sam
Message 6 of 9
Jeff_M
@bfalconr2 @sam.cutbirth , this lisp by Lee Mac may be of interest to you. Dimensions aren't quite as simple to set the mask, but Lee found a way to do it using a DimensionStyleOverride.
http://lee-mac.com/mask.html
Jeff_M, also a frequent Swamper
Message 7 of 9
sam.cutbirth
in reply to: Jeff_M
Hi Jeff!  Long time, no see 🙂  I don't visit the forums as often as I'd like.. Thanks for the link, and have a great weekend!
Sam
Message 8 of 9
bfalconr2
in reply to: Jeff_M
it is just what I needed thank you all!!
Message 9 of 9
SergeiFilippov
Thank you @stacy.dunn !  Great LISP!
Is there a variable that can control offset factor? or is there default I have to preset in my settings?
Rail Community
