Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Alignment Station OffSet Label
4 REPLIES 4
alexisgacia
840 Views, 4 Replies
Good day.
Im trying to find a solution to get the exact elevation of the profile but the data that I get is sometimes not the data that I wanted.
The reason is there are 2 or more profiles are listed and I cannot identify which is the correct data.
c3d_ProfIDCol = c3d_Alignment.GetProfileIds()    <- Here 2 or more profiles are listed
C3D_Profile = acTrans.GetObject(c3d_ProfIDCol.Item(0), OpenMode.ForRead)
C3D_Profile.ElevationAt(RefPtStation)
What Im trying to get is the PGL elevation base on the provided PtStation. And to Identify the profile name.
Thanks and best regards,
Alexis
4 REPLIES 4
Jeff_M
in reply to: alexisgacia
One way, use an extension method to get the desired Profile.
    public static class AlignmentExtensions
        public static ObjectId GetProfileIdByName(this Alignment align, string name)
            var retval = ObjectId.Null;
            using (OpenCloseTransaction tr = HostApplicationServices.WorkingDatabase.TransactionManager.StartOpenCloseTransaction())
                foreach (ObjectId id in align.GetProfileIds())
                    var prof = (Profile)tr.GetObject(id, OpenMode.ForRead);
                    if (prof.Name == name)
                        retval = id;
                        break;
                return retval;
Then you can be sure to get the correct Profile:
                var profId = align.GetProfileIdByName("B31-VA");
                if (profId == ObjectId.Null)
                    return;
                var prof = (Profile)tr.GetObject(profId, OpenMode.ForRead);
Jeff_M, also a frequent Swamper
alexisgacia
in reply to: Jeff_M
Hi Jeff,
Thanks for the reply.
Is it possible to identify the "B31-VA" from the selected label?
What I'm trying to achieve is to extract the profile data from the selected label.
Alex
Jeff_M
OK, Alex. This can be done, but is a bit odd how to get it. This is a snip out of larger code where I test the selected object as being various object types. This is where it's determined to be a StationOffset label.
                            if (ent.GetType() == typeof(CivDb.StationOffsetLabel))
                                var lbl1 = (CivDb.StationOffsetLabel)ent;
                                var txtcmpntIds = lbl1.GetTextComponentIds();
                                foreach(ObjectId txtId in txtcmpntIds)
                                    var txt = tr.GetObject(txtId, OpenMode.ForRead) as CivDb.Styles.LabelStyleReferenceTextComponent;
                                    if (txt == null || txt.General.ReferenceTextObjectType != "Profile")
                                        continue;
                                    var profId = lbl1.GetReferenceTextTarget(txtId);
                                    var prof = (CivDb.Profile)tr.GetObject(profId, OpenMode.ForRead);
                                    var profName = prof.Name;
alexisgacia
in reply to: Jeff_M
Hi Jeff,
What I did is similar to your code. The below code what I used to extract the elevation from profile.
I am new to dotnet and still trying to understand the process.
    Private Function getPGLElevationAtPtStation(acTrans As Transaction, pStationLabel As DatabaseServices.Label, mRefPtStation As Double) As Double
        Dim obj As Object
        Dim oRefId As ObjectId
        Dim C3D_LSTC As DatabaseServices.Styles.LabelStyleTextComponent
        Dim C3D_LSRTC As DatabaseServices.Styles.LabelStyleReferenceTextComponent
        Dim C3D_Profile As DatabaseServices.Profile
        getPGLElevationAtPtStation = vbNull
        For Each obj In pStationLabel.GetTextComponentIds()
            obj = obj.GetObject(OpenMode.ForRead)
            If (obj.GetType.Name.ToString() = "LabelStyleTextComponent") Then
                C3D_LSTC = obj
                'ListBox1.Items.Add("    Components Name : " & C3D_LSTC.Name.ToString())
            ElseIf (obj.GetType.Name.ToString() = "LabelStyleReferenceTextComponent") Then
                C3D_LSRTC = obj
                'Debug.Print(C3D_LSRTC.Name)
                If Not (C3D_LSRTC Is Nothing) Then
                    oRefId = pStationLabel.GetReferenceTextTarget(C3D_LSRTC.ObjectId)
                    If (oRefId.ToString = "(0)") Then Exit Function
                    obj = acTrans.GetObject(oRefId, OpenMode.ForRead)
                    If (TypeOf obj Is DatabaseServices.Profile) Then
                        C3D_Profile = obj
                        getPGLElevationAtPtStation = C3D_Profile.ElevationAt(mRefPtStation).ToString()
        Next
    End Function
Thank you for your support. Its a huge help again.
Rail Community
