Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Adding Points to Point Group
6 REPLIES 6
David_Prontnicki
1655 Views, 6 Replies
I am trying to add points to a point group. The problem that I am having is that creating a StandardPointGroupQuery will overwrite the point numbers already in the group. How do I just ADD to the existing point numbers.
I was thinking of getting all the point numbers and building that back into the new query but I am having no luck with that. Any help would be greatly appreciated.
    Public Sub CogoPointNoDisplay()
        'Get the current document and database
        Dim docEd As Editor = Active.Editor
        Dim curDb As Database = Active.Database
        Dim civDoc As CivilDocument = Active.CivilDocument
        Dim cmdloop As Boolean = True
        Try
            'Start command loop
            Do While cmdloop
                'Start selection options
                Dim acSSPrompt As New PromptEntityOptions(vbLf & "Select a COGO Point to set to _No Display: ")
                acSSPrompt.SetRejectMessage(vbLf & "Invalid Selection. Selected item is not a COGO point. Please select again." & vbLf)
                acSSPrompt.AddAllowedClass(GetType(CogoPoint), True)
                'Set selection set
                Dim acSSet As PromptEntityResult = docEd.GetEntity(acSSPrompt)
                'If selection is a cogo point
                If acSSet.Status <> PromptStatus.OK Then
                    Return
                End If
                'Start the transaction
                Using acTrans As Transaction = curDb.TransactionManager.StartTransaction()
                    'Set dbobject and open for write
                    Dim acdbObj As Autodesk.AutoCAD.DatabaseServices.DBObject = acTrans.GetObject(acSSet.ObjectId, OpenMode.ForWrite)
                    'Set and cast point
                    Dim acCogoPoint As CogoPoint = TryCast(acdbObj, CogoPoint)
                    'Get point number
                    Dim acCogoPointNumber As String = acCogoPoint.PointNumber.ToString()
                    'Get _No Display point group
                    Dim pointGroupId As ObjectId = civDoc.PointGroups.Item("_No Display")
                    Dim pointGroup As PointGroup = TryCast(pointGroupId.GetObject(OpenMode.ForWrite), PointGroup)
                    Dim existPoints As String = pointGroup.GetPointNumbers.ToString()
                    'Set new query parameters
                    Dim standardQuery As StandardPointGroupQuery = New StandardPointGroupQuery()
                    standardQuery.IncludeNumbers = existPoints & ";" & acCogoPointNumber
                    'Set query
                    pointGroup.SetQuery(standardQuery)
                    'Update point group
                    pointGroup.Update()
                    'Save the changes and dispose of the transaction
                    acTrans.Commit()
                End Using
            Loop
        Catch ex As Exception
       'Intentionally left out
        End Try
        docEd.Regen()
    End Sub
6 REPLIES 6
Jeff_M
in reply to: David_Prontnicki
You should probably move the updating of the PG out of the loop. Collect a list of the Point Numbers to add to the PG, then use the PG.GetQuery() method. Test to see if the Query type is a custom query, if so notify the user that it cannot be edited (at least it wasn't editable in the past, I haven't checked recently). Cast it to a StandardPointGroupQuery then get the ExcludeNumbers property, run through the list of numbers to add to the PG and remove any found in the Exclude list and add the excluded numbers back query.ExcludeNumbers = excludednumbers. Then create new list for numbers, add the PG array from PG.GetPointNumbers(), run through your collected point numbers you want to add, check if the PG already includes any point numbers, if not then add that number to the new list. Next, set the IncludeNumbers to that updated list. Finally, set the PG Query to the modified query.
You may want to have a function to create a ranged list of strings so adjacent numbers will become 1-6,8-34,40,42-44, etc. See a post I made yesterday with such a function in lisp.
David_Prontnicki
in reply to: Jeff_M
WOW! Thank you Jeff.
OK, let me digest this and take a stab at it. But the jist of it is:
1.) Get the new point numbers
2.) Get the existing included and excluded point numbers
3.) Create new query with existing and new and excluded point numbers
4.) Update group
Right? That is what I thought the approach would be, I was having an issue trying to get the existing numbers from the PG.GetPointNumbers. It is type UIntiger.
David_Prontnicki
in reply to: Jeff_M
@Jeff_M
OK, so here is where I am at:
  1. You should probably move the updating of the PG out of the loop. I removed the loop and went with PromptSelectionOptions with a filter instead. Works better that way anyway.
  2. Collect a list of the Point Numbers to add to the PG, then use the PG.GetQuery() method. Created a New List(of String) for the selected point numbers. Used the GetQuery to get existing information.
  3. Test to see if the Query type is a custom query, if so notify the user that it cannot be edited (at least it wasn't editable in the past, I haven't checked recently). I cant seem to figure out how to check if there is a custom query. I don't see how to access that. Any help would be great.
  4. Cast it to a StandardPointGroupQuery then get the ExcludeNumbers property, run through the list of numbers to add to the PG and remove any found in the Exclude list and add the excluded numbers back query.ExcludeNumbers = excludednumbers. I "cast'ed" the GetQuery to a Standard and extracted the included and excluded point numbers to a string.
  5. Then create new list for numbers, add the PG array from PG.GetPointNumbers(), run through your collected point numbers you want to add, check if the PG already includes any point numbers, if not then add that number to the new list. Next, set the IncludeNumbers to that updated list. Finally, set the PG Query to the modified query. I created a NEW query with StandardQuery including the original points and the new points to add.
  6. You may want to have a function to create a ranged list of strings so adjacent numbers will become 1-6,8-34,40,42-44, etc. See a post I made yesterday with such a function in lisp. I saw your LiSP from yesterday and defiantly want to take you up on this suggestion as it makes complete sense. But I cant figure out how to convert that LiSP to VB as I have not done LiSP in years. Is this something you would be will to help me out with?
Here is the modified code so far:
        Try
            'Create a typedvalue array to define the filter criteria
            Dim acTypValAr(0) As TypedValue
            acTypValAr.SetValue(New TypedValue(DxfCode.Start, "AECC_COGO_POINT"), 0)
            'Assign the filter criteria to a selectionfilter object
            Dim acSelFtr As New SelectionFilter(acTypValAr)
            'Start cogo point selection prompt option
            Dim promptSelectionOptions As New PromptSelectionOptions
            promptSelectionOptions.MessageForAdding = (vbLf & "Select COGO Points to ADD to the _No Display point group: ")
            promptSelectionOptions.MessageForRemoval = (vbLf & "Select COGO Points to REMOVE from the selection set: ")
            'Get prompt selection results
            Dim cogoPointPromptSelectionResult = docEd.GetSelection(promptSelectionOptions, acSelFtr)
            'Set selection set
            Dim cogoPointSelectionSet As SelectionSet = cogoPointPromptSelectionResult.Value
            'If selection are cogo points
            If cogoPointPromptSelectionResult.Status = PromptStatus.OK Then
                    Dim selectedCogoPointNumbers As New List(Of String)
                    For Each selectedCogoPoint In cogoPointSelectionSet
                        Dim acdbObj As Autodesk.AutoCAD.DatabaseServices.DBObject = acTrans.GetObject(selectedCogoPoint.ObjectId, OpenMode.ForRead)
                        'Set and cast point
                        'Get point number
                        selectedCogoPointNumbers.Add(acCogoPointNumber)
                    Next
                    Dim cogoPointsToAdd As String = String.Join(",", selectedCogoPointNumbers)
                    'Get existing point group query/information
                    Dim getExistQuery As PointGroupQuery = pointGroup.GetQuery
                    Dim existQuery As StandardPointGroupQuery = TryCast(getExistQuery, StandardPointGroupQuery)
                    Dim includedNumbers As String = existQuery.IncludeNumbers.ToString()
                    Dim excludedNumbers As String = existQuery.ExcludeNumbers.ToString()
                    Dim newStandardQuery As StandardPointGroupQuery = New StandardPointGroupQuery()
                    newStandardQuery.IncludeNumbers = includedNumbers & "," & cogoPointsToAdd
                    newStandardQuery.ExcludeNumbers = excludedNumbers
                    'Set query
                    pointGroup.SetQuery(newStandardQuery)
                    'Update point group
                    pointGroup.Update()
                    acTrans.Commit()
                End Using
            End If
            ''Initiate error message box
        End Try
        docEd.Regen()
    End Sub
Jeff_M
@David_Prontnicki wrote:
@Jeff_M
  1. You should probably move the updating of the PG out of the loop. I removed the loop and went with PromptSelectionOptions with a filter instead. Works better that way anyway.  Good
  2. Collect a list of the Point Numbers to add to the PG, then use the PG.GetQuery() method. Created a New List(of String) for the selected point numbers. Used the GetQuery to get existing information. Good
  3. Test to see if the Query type is a custom query, if so notify the user that it cannot be edited (at least it wasn't editable in the past, I haven't checked recently). I cant seem to figure out how to check if there is a custom query. I don't see how to access that. Any help would be great. Use GetType(), or I think you can TryCast()
  5. Then create new list for numbers, add the PG array from PG.GetPointNumbers(), run through your collected point numbers you want to add, check if the PG already includes any point numbers, if not then add that number to the new list. Next, set the IncludeNumbers to that updated list. Finally, set the PG Query to the modified query. I created a NEW query with StandardQuery including the original points and the new points to add. No, you don't need to create a new StandardQuery. Use the one you got from the PointGroup.
  6. You may want to have a function to create a ranged list of strings so adjacent numbers will become 1-6,8-34,40,42-44, etc. See a post I made yesterday with such a function in lisp. I saw your LiSP from yesterday and defiantly want to take you up on this suggestion as it makes complete sense. But I cant figure out how to convert that LiSP to VB as I have not done LiSP in years. Is this something you would be will to help me out with? I'd help, but VB to me is about the same as lisp for you I imagine. I can do lisp and c#, but VB is not something I am good with...I can read it, mostly, but writing in it is another thing.
Here is the modified code so far:<snip>
Jeff_M
A Uint is just a positive integer. The CogoPoint.PointNumber is also a Uint...
David_Prontnicki
in reply to: Jeff_M
@Jeff_M
First, Thank you so much for your help and patience. I really appreciate it.
I am working to figure out the check for custom. Thank you for the point in the right direction.
I do speak c#! 🙂 😉
But in all seriousness, thank you for everything.
Rail Community
