Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Adding Boundary Definition to TIN Surface in Civil 3D
4 REPLIES 4
heyimsp12
428 Views, 4 Replies
I'm trying to create a new TIN surface and add definitions for Breaklines and Boundary using following lines of code and constantly running into error: "Invalid input for breaklines". Not sure why.
public void CreateTinSurface(ObjectIdCollection BoundaryIdCollection)
            var ed = Application.DocumentManager.MdiActiveDocument.Editor;
            var db = Application.DocumentManager.MdiActiveDocument.Database;
            var civilDoc = CivilApplication.ActiveDocument;
            using (var trans = db.TransactionManager.StartTransaction())
                try
                    //Select a surface style
                    ObjectId styleId = civilDoc.Styles.SurfaceStyles[1];
                    if (styleId == null | BoundaryIdCollection == null)
                        throw new Exception("Either Style Id or BoundarySet is empty.");
                    //Creating an empty TIN Surface
                    ObjectId surfaceId = TinSurface.Create("TIN_Surface_From_boundary", styleId);
                    TinSurface surface = (TinSurface)trans.GetObject(surfaceId, OpenMode.ForWrite);
                    //Add Breaklines to the surface
                    //Next line is where I get error thrown.
                    SurfaceDefinitionBreaklines surfaceBreaklines = surface.BreaklinesDefinition;
                    //surfaceBreaklines.AddNonDestructiveBreaklines(BoundaryIdCollection, 1.0);
                    surfaceBreaklines.AddProximityBreaklines(BoundaryIdCollection, 1.0);
                    //Access the Boundaries Definition object from the Surface Object
                    SurfaceDefinitionBoundaries surfaceboundaries = surface.BoundariesDefinition;
                    surfaceboundaries.AddBoundaries(BoundaryIdCollection, 1.0, Autodesk.Civil.SurfaceBoundaryType.Outer, true);
                catch (Exception ex)
                    Application.ShowAlertDialog("Error creating Tin surface.");
                trans.Commit(); //End transaction
Need help!!
Labels (3)
4 REPLIES 4
Jeff_M
in reply to: heyimsp12
What object types are you passing for the breaklines?
heyimsp12
in reply to: Jeff_M
I'm passing ObjectIdCollection which contains ObjectIds of enclosed Boundaries made out of lines and Polylines.
Jeff_M
Use the AddStandardBreaklines since the surface is empty. ProximityBreaklines use the nearest triangle vertex to get the elevation for the breaklines. An empty surface has no triangles to use. In the C3D editor you can do this, but I believe C3D catches the error and uses the Standard breakline option.
heyimsp12
in reply to: Jeff_M
Thanks @Jeff_M
This worked like a charm.
Rail Community
