Want to set corridor surface checkbox checked or unchecked using API.
I am adding existing corridor surface to new corridor using its "SurfaceStyleId"(surface names are different in both corridors).
But after adding this surface to new corridor I found that original corridor surface gets unchecked and I need it as it was (checked or unchecked).
So I want the corridor API which will set checkbox 'checked' or 'unchecked'.
Please find attached screen shot.
Please suggest me the API to do this.
Mahesh.
Jeff_M
So you want a surface to be updated by both corridors? This seems like it shouldn't be allowed, hence why the original one becomes unchecked. I think I would create a new surface and paste both corridor surfaces into it in order to do what I think you are wanting.
Jeff_M, also a frequent Swamper
