Visual Studio debug issues after installing Autodesk Subassembly Composer
After installing Autodesk Subassembly Composer, I can no longer debug .Net applications.  I get the following error:  "The debugger's protocol is incompatible with the debuggee".  Uninstalling Autodesk Subassembly Composer solves the problem.  I'm guessing this is a .Net 3.5/4 issue.  Anyone else seeing this?  Does this occur using VS2010?
Steve
Windows 7 64-bit
Civil3D 2011
Visual Studio 2008
Jeff_M
SAC changes the acad.exe.config file to specify the use of .NET 4.0. I haven't tested this, but you should be able to use the same workaround as that suggested for 2012:
http://civilizeddevelopment.typepad.com/civilized-development/2011/04/developing-applications-for-au...
Jeff_M, also a frequent Swamper
Thanks for this info, Jeff. For now I'm going to run SAC on a VM.  Sounds like VS2010 will be the best option when moving to 2012.
