vb.net Create Waterdrop in a surface
jmmarin
Message 1 of 11
jmmarin
Hi all.
I am trying to create a waterdrop in a surface. I have found some examples in Internet, but it does not work. I think it is due changes in versions from 2013.
I have loaded the following two references (not sure if they are the correct or additionals are needed):
Autodesk.AECC.Interop.Land
Autodesk.AECC.Interop.UILand
The code I found is the following, but it does not work when the function "CreateWaterdrop(Point2d location, WaterdropObjectType objectType)" is called:
Dim drops As New ObjectIdCollection()
For Each triangle As TinSurfaceTriangle In surface.Triangles
  Dim centroid As Point2d = _
           getTriangleCentroid(triangle)
  ' calculate water-drop for the centroid
  Dim oid As ObjectIdCollection = _
    surface.Analysis.CreateWaterdrop(centroid, _
    Autodesk.Civil.Land.WaterdropObjectType.Polyline3D)
    ' Save all the water-drops
    For Each id As ObjectId In oid
      drops.Add(id)
    Next
Next
I understand the code, but my problem is the function...
Thanks in advance.
Replies (10)
Message 2 of 11
Jeff_M
@jmmarin You do not need to reference the COM libraries. The waterdrop type should be:
Autodesk.Civil.WaterdropObjectType.Polyline3D
That should allow it to work. With the Land in there you were mixing COM and .NET API types.
Jeff_M, also a frequent Swamper
Message 3 of 11
jmmarin
Hi @Jeff_M .
Thanks for your answer.
Ok. I have done what you suggest. The object is correct but, however, the collection is filled with objects without IDs... I do not know why. Maybe lack of knowlege (again...).
The code is the following. I use two auxiliary functions to find the SurfaceID and also to obtain the point.
I also attach the model with the surface.
I hope this helps to guide me. Thanks.
'Get surface ID
    Public Shared Function obtenerSurfacePorNombre(SURFACE_NAME As String) As TinSurface
        Dim docCol As Autodesk.AutoCAD.ApplicationServices.DocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
        Dim aDoc As Document = docCol.MdiActiveDocument
        Dim acadDb As Database = aDoc.Database
        Dim m_Editor As Editor = aDoc.Editor
        Dim m_doc As CivilDocument = CivilApplication.ActiveDocument()
        Dim surfaceSel As TinSurface
        Dim surfaceCol As ObjectIdCollection
        Dim surfaceId As ObjectId
        Dim surf As TinSurface
        Dim auxName As String
        surfaceCol = m_doc.GetSurfaceIds
        Using m_Trans As Transaction = acadDb.TransactionManager.StartTransaction()
            For i = 0 To surfaceCol.Count - 1
                surfaceSel = surfaceCol.Item(i).GetObject(OpenMode.ForRead)
                auxName = surfaceSel.Name
                If auxName = SURFACE_NAME Then
                    surfaceId = surfaceSel.Id
                    Exit For
            Next
            surf = m_Trans.GetObject(surfaceId, OpenMode.ForRead)
            m_Trans.Commit()
        End Using
        Return surf
    End Function
    Public Shared Sub crearWDP()
        Dim surfName As String
        'Get objectID of the surface
        surfName = "ELMYA_Z1"
        surf = PV_DRENAJE_main.obtenerSurfacePorNombre(surfName)
        For Each triangle As TinSurfaceTriangle In surf.Triangles
            Dim centroid As Point2d = getTriangleCentroid(triangle)
            Dim oid As ObjectIdCollection = surf.Analysis.CreateWaterdrop(centroid, Autodesk.Civil.WaterdropObjectType.Polyline3D)
                drops.Add(id)
            Next
        Next
    End Sub
    Public Shared Function getTriangleCentroid(triangle As TinSurfaceTriangle) As Point2d
        ' The centroid is calculated from the cx and cy being:
        ' cx = (v1x + v2x + v3x) / 3
        ' cy = (v1y + v2y + v3y) / 3
        Dim cx As Double = (triangle.Vertex1.Location.X + triangle.Vertex2.Location.X + triangle.Vertex3.Location.X) / 3
        Dim cy As Double = (triangle.Vertex1.Location.Y + triangle.Vertex2.Location.Y + triangle.Vertex3.Location.Y) / 3
        Return New Point2d(cx, cy)
    End Function
to guide me...
Message 4 of 11
Jeff_M
Your code works just fine. It creates a waterdrop from each and every TinTriangle (7000+!). The ObjectIdCollection contains the ObjectId of each of those Polyline3d entities. It does make for a cool looking surface!
Message 5 of 11
jmmarin
Hi @Jeff_M ,
thanks for your answer.
I am surprised because it does not work in my project... The routine ends without drawing any polyline. I attach a capture of the ObjectIdCollection "drops". You can see that each element is empty and there are no objectIDs:
"drops" is being collecting objects but they do not have objectID. It should be the problem, but I do not know why. As you show, polylines are correctly created so "drops" should be filled with objectID...
Thanks.
Message 6 of 11
Jeff_M
@jmmarin I just tested again, and it is working as expected for me. So let's check some things...what release of Civil 3D are you using? Are all Updates applied? I've tested in both C3D 2022 & 2023:
Message 7 of 11
jmmarin
Hi @Jeff_M
I am using C3D 2023:
It is the same that you show.
I have trying different options and I am not able to get a ObjectID collection as expected.
In order to discard issues, these are the imports that I have in the module. Do I need reference any additional library?
Imports System
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.DatabaseServices.ObjectId
Imports Autodesk.Civil.DatabaseServices.Styles
Imports Autodesk.Civil.ApplicationServices
Imports Autodesk.AutoCAD.Colors
Imports AutoCAD
Imports System.Security.Cryptography.X509Certificates
Imports System.Windows.Forms
Imports Autodesk.AutoCAD.Windows
Imports Autodesk.AutoCAD.DatabaseServices.Filters
Imports System.Data.Common
Imports AXDBLib
Imports Autodesk.AutoCAD.ApplicationServices.Core
Imports Autodesk.Civil.Settings
Imports Autodesk.Aec.Geometry
Imports Profile = Autodesk.Civil.DatabaseServices.Profile
Thanks again.
Message 8 of 11
Jeff_M
These are all the Imports I have.
And this is how I am calling the Sub:
    <CommandMethod("jmSurfaceTest")>
    Public Sub surfacetest()
        crearWDP()
    End Sub
Message 9 of 11
jmmarin
Hi @Jeff_M.
I have included a DocumentLock prior the loop and it has worked! "drops" are filled with 7000+ obtectIDs.
I have remembered that you suggested me doing that for a previous routine.
Just to understand (and learn), why is it required?.
Regards.
Message 10 of 11
Jeff_M
If you are calling the tool from a form you should always lock the document. It is always a good idea when asking for help to include the fact it is being run from a form.
Message 11 of 11
jmmarin
Ok Jeff. Understood.
I included the form later and I supposed it was not relevant.
Your help has been very useful. Thanks.
