Unable to Locate Autodesk.Civil.DatabaseServices.dll in Civil 3D 2024
CHEETAH696NM8
Message 1 of 9
CHEETAH696NM8
I am new to using Visual Studio and currently working with Civil 3D 2024. I am trying to reference the Autodesk.Civil.DatabaseServices.dll in my project, but I am unable to find the file. Could someone kindly guide me on how to locate and reference this DLL in Visual Studio?
Thank you for your help!
Replies (8)
Message 2 of 9
Jeff_M
There is no such file. These are the .NET files needed:
Message 3 of 9
cturlington
Jeff M,
You previously replied that, regarding these files "Autodesk.Civil.DatabaseServices.dll" and "Autodesk.Civil.dll," they are no longer provided.  But you did not mention what they use as a replacement for them to have access to the surface API data in Civil 3D 2026.  Trying to write a C# program using the Visual Lisp editor.  Can you help by listing the reference files I need, what they were renamed to, or where I can find these files?
Thanks in advance for any suggestions.
Message 4 of 9
Jeff_M
@cturlington  I'm not sure what , exactly, you mean by this " Trying to write a C# program using the Visual Lisp editor. "
If you are writing a lisp program you will need to reference the COM files. Use this:
(defun getaeccApp (module / *acad* C3D) ;; module must be "Land", "Pipe", "Roadway", or "Survey"
  (vl-load-com)
  (if (and (setq *acad* (vlax-get-acad-object))
	   (setq C3D (strcat "HKEY_LOCAL_MACHINE\\"
			     (if vlax-user-product-key
			       (vlax-user-product-key)
			       (vlax-product-key)
		 C3D (vl-registry-read C3D "Release")
		 C3D (substr
		       C3D
		       1
		       (vl-string-search
			 C3D
			 (+ (vl-string-search "." C3D) 1)
		 C3D (vla-getinterfaceobject
		       (strcat "AeccXUi" module ".Aecc" (if (= (strcase module) "LAND") "" module) "Application." C3D)
    C3D
Message 5 of 9
cturlington
Sorry Jeff,
I meant Visual Studio.
Message 6 of 9
andrewpuller3811
The references Jeff listed above are the ones you need to write a .net programme in visual studio for civil 3d.
Below is a bit more information on what the dlls provide access to and where they are located.
Autocad dlls - Located in C:\Program Files\Autodesk\AutoCAD 2024
AcDbMgd.dll - Used for working with objects stored in a drawing file, such as lines, circles, and blocks.
AcMgd.dll - Provides access to the AutoCAD application and user interface components, including the editor and plotting services.
AcCoreMgd.dll - Contains functionality related to the editor, publishing, plotting, and defining commands.
Civil 3d dlls -
Aecbasemgd.dll - Located in C:\Program Files\Autodesk\AutoCAD 2024\ACA
Aeccdbmgd.dll - Used for working with Civil 3d objects stored in a drawing file, such as surfaces. - Located in C:\Program Files\Autodesk\AutoCAD 2024\C3D
AeccPressurePipesMgd.dll - Used for working with Civil 3d Pressure pipe objects stored in a drawing file. - Located in C:\Program Files\Autodesk\AutoCAD 2024\C3D
Autocad Developer documentation can be found here-
https://help.autodesk.com/view/OARX/2024/ENU/?guid=GUID-71683E52-850F-434E-AD8C-3DB20BCBAD14
Civil 3d Developer documentation can be found here-
https://help.autodesk.com/view/CIV3D/2024/ENU/?guid=GUID-DA303320-B66D-4F4F-A4F4-9FBBEC0754E0
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
Message 7 of 9
cturlington
Thank you, Andrew,
I just did a full C:/ search for the reference names: "AeccCivilDbMgd.dll," "AeccCivilMgd," "AeccLandMgd.dll," "Aecc.Civil.dll," "Aecc.Civil.DatabaseServices.dll," but none were found.  I was hoping to find these in C3d 2026.  But apparently, they are not included in the current download, and alternate references are used in their place. Are these specific ones available on the Autodesk site somewhere?  BTW:  I also have C3d 2024 loaded, so I know they are not in that version either.
Thanks again for your time and suggestions.
Message 8 of 9
andrewpuller3811
You are searching for the wrong files -
The files are named - "AcDbMgd.dll", "AcMgd.dll", "AcCoreMgd.dll", "Aecbasemgd.dll", "Aeccdbmgd.dll"
As above, for civil 3d 2024 they will be found in -
"C:\Program Files\Autodesk\AutoCAD 2024"
"C:\Program Files\Autodesk\AutoCAD 2024\ACA"
"C:\Program Files\Autodesk\AutoCAD 2024\C3D"
For Civil 3d 2026 they will be found in -
"C:\Program Files\Autodesk\AutoCAD 2026"
"C:\Program Files\Autodesk\AutoCAD 2026\ACA"
"C:\Program Files\Autodesk\AutoCAD 2026\C3D"
Andrew Puller
Windows 11
Civil 3d 2023
Message 9 of 9
cturlington
Thank you, Andrew!
That works, knowing the folders to find these in.  I was not familiar with the "ACA" folder.
