Trying to create PropertySetDefinition
naoki.yanagisaki
Message 1 of 8
naoki.yanagisaki
Hi, I'm trying to create Civil3D PorpertySetDefinition with c#.
But faced in some trouble. Code is Below. Please give me advice.
var doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
var db = doc.Database;
var propSetDefName = "MyCustomProp";
var propSetDef = new PropertySetDefinition();
propSetDef.SetToStandard(db);
propSetDef.SubSetDatabaseDefault(db);
propSetDef.Description = "This is sample description";
var appliedTo = new StringCollection();
appliedTo.Add("");                                   // <- I want to define SOLID3D, but I don't know the word.
propSetDef.SetAppliesToFilter(appliedTo,false)
Replies (7)
Message 2 of 8
hosneyalaa
Message 4 of 8
hippe013
This is what I get from the filter when set to apply to Solid 3D.
"AcDb3dSolid"
Message 5 of 8
naoki.yanagisaki
Thank you.
I was helpful.
Trouble is solved by below code.
RXObject.GetClass(typeof(Solid3d)).Name       // I can get "AcDb3dSolid" by this code.
Message 6 of 8
naoki.yanagisaki
That's good.
My trouble was solved by "AcDb3dSolid"
Message 7 of 8
Ta7a
in which namespace exist the PropertySetDefinition class , as I can't access it in my solution
Message 8 of 8
naoki.yanagisaki
In order to use "PropertySetDefinition" class, you need to add some dll to solution.
I used below dll. They all are located in "C:\Program Files\Autodesk\AutoCAD 2021"
accoremgd
acdbmgd
acmgd
AecBaseMgd
AeccDbMgd
AecPropDataMgd
AecUIWindows
PropertySetDefinition refer AecPropDataMgd. And namespace is "Autodesk.Aec.PropertyData.DatabaseServices"
