The volume surface does not appear in volumes dashboard
Ahmmed-saber
Ahmmed-saber
 The next code to create a volume surface
but the new volume surface does not appear in the volumes dashboard , i wont to add it by code
public void CreateVolSurfae()
               Document acDoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
               Editor ed = acDoc.Editor;
               Database acCurDb = acDoc.Database;
               CivilDocument acCivilDoc = CivilApplication.ActiveDocument;
               try
                    using (Transaction ts = Application.DocumentManager.MdiActiveDocument.Database.TransactionManager.StartTransaction())
                         string surfaceName = "Volume-01";
                         var surOpt01 = new PromptEntityOptions("\n Select the base surface");
                         surOpt01.SetRejectMessage("\nSelect surface only");
                         surOpt01.AddAllowedClass(typeof(TinSurface), true);
                         var surSelect01 = ed.GetEntity(surOpt01);
                         if (surSelect01.Status != PromptStatus.OK) return;
                         if (surSelect01.Status == PromptStatus.OK)
                              var baseSurface = surSelect01.ObjectId;
                              var surOpt2 = new PromptEntityOptions("\n Select the compariso surface");
                              surOpt2.SetRejectMessage("\nSelect surface only");
                              surOpt2.AddAllowedClass(typeof(TinSurface), true);
                              var surSelect02 = ed.GetEntity(surOpt2);
                              if (surSelect02.Status != PromptStatus.OK) return;
                              if (surSelect02.Status == PromptStatus.OK)
                                   var surfaceId2 = surSelect02.ObjectId;
                                   ObjectId surfaceStyleId = acCivilDoc.Styles.SurfaceStyles[3];
                                   ObjectId surfaceIdvol = TinVolumeSurface.Create(surfaceName, baseSurface, surfaceId2, surfaceStyleId);
                                   TinVolumeSurface volumSurface = surfaceIdvol.GetObject(OpenMode.ForWrite) as TinVolumeSurface;
                                   volumSurface.Rebuild();
                                   volumSurface.GetVolumeProperties();
                         ts.Commit();
               catch (System.Exception ex)
                    ed.WriteMessage("Failed happen" + ex.Message);
hosneyalaa
Hi @Ahmmed-saber
I think  civil 3d Api  is not supported
Richard-Lionheart
I've always had to add it manually in the table.
