Subassembly Composer
Does anyone know if there is a discussion group for the 2012 Subassembly Composer software? I am trying to create a typical road section that cannot be created out of the box with C3D 2012 and have a few questions (see attachment). I have added all the points, links and shapes in Subassembly Composer and can add it to my Tool Palette in C3D. I can also create a corridor with it but I cannot change any of the parameters of the subassembly in C3D once I have created the corridor. I suspect I have to add code to the points/links in Subassembly Composer?? Thanks in advance.
You can find a documentation about Autodesk Subassembly Composer on wikihelp:
for Civil 3D 2012 and 2011 here: http://wikihelp.autodesk.com/AutoCAD_Civil_3D/enu/2012/Help/Autodesk_Subassembly_Composer
for Civil 3D 2013 here:
http://wikihelp.autodesk.com/AutoCAD_Civil_3D/enu/2013/Help/Autodesk_Subassembly_Composer
If you cannot change any of the parameters of the subassembly in C3D probably you didn't add the input parameters. Check this link:
http://wikihelp.autodesk.com/AutoCAD_Civil_3D/enu/2012/Help/Autodesk_Subassembly_Composer/0018-Tool_...
(Home > AutoCAD Civil 3D > English > 2012 > Help > Autodesk Subassembly Composer > Tool Reference > Settings and Parameters Panel > Input/Output Parameters Tab)
