Spot elevation command
ym.56789
ym.56789
Hi, I am trying to create a custom command in the CUI that will help me create spot elevations faster.
I can use the command CREATEPOINTSLOPEGRADEDIST to create my new point at a specified grade from a reference point, but there are so many prompts that I find the command is not so usefull for me.
My command string is currently as follows: ^C^C._AeccCreatePointSlopeGradeDist;nod;\\G;\;0;0;Y;;
I have spent an inordinate amount of time trying to get this to work, but can't seem to nail it down. When performing the command manually here are the steps:
1. Snap to the node of a point (this will ensure I get that point's elevation)
2. Choose my new point location.
3. use G for grade and enter my grade.
4. hit enter to skip choosing a distance (this will use my prevuously selected point)
5. use 0 points in between, 0 offsets, Y for endpoint, and no description.
Then I arrive at my new point as I would like, for some reason I can't replicate this command in the CUI. Any help is really appreciated.
Thank you.
kmohs
You can try starting with something like this:
^C^C.osmode;8;._AeccCreatePointSlopeGradeDist;\\G;\;0;0.00;Y;;^C
ym.56789
Thanks, the command works, but for some reason the point is not showing up...
I have resorted to writing a custom .NET command - hopefully I will get something working.
