Selecting objects with specific extended data in a script (lisp or dynamo)
filip
Message 1 of 15
filip
I do not find the extended data of an object bij selection with (car (entsel)) in lisp
Is there a way to view the extended data and modify it  ?
I have no experience with Dynamo-scripts, but maybe there allreday exist a script for these issue.
Replies (14)
Message 2 of 15
hosneyalaa
@filip
Can you attached example drawing
Message 3 of 15
filip
In attach you find a dwg with many objects where we add extended data properties.
For instance :
- tree (Block "Boom_1") has xdata "Bouwheer" (= the builder) or "Type" (= sort of tree)
- haches, lines, pipes and structures have also extra properties according to make tables of quantities
- in the xref 'IMKL' you can see the location of the gas pipes, waterpipes, cables, ... of different compagnies with extended data of the sort of cable or pipe.
I 'm interested in a script that can select objects by property of the extended data and can modify the extended data. I looked in the database (with a dxf-file, search in the file by entityname or by vlax-ename) but i didn't find the extended data-properties.
See also https://help.autodesk.com/view/CIV3D/2024/ENU/?guid=GUID-A94BC605-5517-437F-A6FE-D3EB8116A01A
Message 4 of 15
hosneyalaa
hi
I did not find  Xdata
do you mean  property sets
Message 5 of 15
filip
Yes, where can I find these properties in the database ?
Message 6 of 15
hosneyalaa
Message 7 of 15
filip
Thanks for the script, it works.
I'm still interested how to manage the property sets in lisp, because I don't understand why I can't see the group code -3 of the entity. Is the desciption of the help-page https://help.autodesk.com/view/CIV3D/2024/ENU/?guid=GUID-A94BC605-5517-437F-A6FE-D3EB8116A01A mislea...
Message 8 of 15
hosneyalaa
@filip
Can you reading this
Until you are  understand Extended Entity Data
https://www.afralisp.net/autolisp/tutorials/extended-entity-data-part-1.php
Message 9 of 15
filip
Is the conclusion that "extended entity data" (see example Afralisp) and the extended data of property sets are two different things ? That's really confusing !
Message 10 of 15
hosneyalaa
Message 11 of 15
filip
Yes, that's exactly what we do in our drawing that I send you : we make our own data-fields.
But why we can't see them in the list of entity groupcodes ?
I was thinking that the 330 or 360-codes maybe hide these data
In AutoCAD Help I found this :  https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-51B921F2-16CA-4948-AC75-196198DD1796
Message 12 of 15
Jeff_M
Because property sets are an Architecture based feature and is not available for Civil3D/AutoCAD users in lisp. It is available in .NET, which makes it available in Dynamo.
Message 13 of 15
filip
Thank you, Jef !
Message 14 of 15
ahuygen
Project Explorer can be used to access all property set data in dwg . Also filter and select them. like a data table tool.
Message 15 of 15
willem.creffierKCWFB
Hi @filip
yes, reading the values of extended data seems useful, but apparently it only exists for Map features or Cogo Points.
Did you proceed on this?
Kind regards,
Willem
