Re-using Selection Set
jhoageN5XUG
jhoageN5XUG
I'm working on a LISP that will allow the user to create a selection set.  The LISP will then convert specific layers within that selection set to another designated layer.  I would like to keep referencing ss1 using (ssget "_P") but that only references the most recently created selection set.
I also tried copying the selection set using ssadd later in the program, but that was unsuccessful too.
(defun c:sslaychange ()
    (vl-load-com)
(setq ss1(ssget))
(princ)
  (if (tblsearch "LAYER" "V-BLDG-OTLN-F")
    (progn
      (setq e (ssget "_P" '((8 . "V-BLDG-OTLN-F"))))
       (command "_.change"e "" "P" "LA" "V-BLDG-OTLN" "")
(princ)
(setq e nil)
  (if (tblsearch "LAYER" "V-WATR-UNDR-F")
    (progn
      (setq e (ssget "_P" '((8 . "V-WATR-UNDR-F"))))
       (command "_.change"e "" "P" "LA" "V-WATR-UNDR-E" "")
(princ)
Jeff_M
@jhoageN5XUG give this a try:
(defun c:sslaychange ( / e ss1)
  (vl-load-com)
  (setq ss1(ssget))
    (progn
      (sssetfirst nil ss1)
      (setq e (ssget '((8 . "V-BLDG-OTLN-F"))))
      (command "_.change" e "" "P" "LA" "V-BLDG-OTLN" "")
    (progn
      (setq e (ssget '((8 . "V-WATR-UNDR-F"))))
      (command "_.change" e "" "P" "LA" "V-WATR-UNDR-E" "")
  (princ)
Jeff_M, also a frequent Swamper
jhoageN5XUG
Not quite, I'll keep tweaking to see if I can get it to work.
