Possible Network bug?
norman.yuan
Mentor Mentor
norman.yuan
I am working on C3D development project where I have code to access Network object. Surely it is simple enough to simply call
CivilDocument.GetNetworkIds()
Since I have to repeatedly test my code on different drawings, sometimes I just copy drawing content with network included to another blank drawing to run my debugging/testing. I use Clipboard Copy/Paste to do it. Then I found, in the drawing where the drawing content is pasted, the GetNetworkIds() would return 2 network IDs in spite the copied drawing content only has one network in it. If the code opens the 2 DIFFERENT network ObjectIds as Netowrk objects, both has the same Name, and the same other properties. That is, the 2 are identical. Yes, the Prospector in Tool Space paletteSet only show one network exists.
If I save the drawing. close and then open it again, there would only be one network, as expected.
So, I assume it is somehow a bug with C3D. And with this bug, if running code related to network with a drawing that has network just copied from external drawing, this bug could be hit.
Now that I know reopening the drawing would avoid this issue, I am curious to know whether anyone comes across this. Or maybe, with C3D network, one should never copy from one drawing to another?
Norman Yuan
Drive CAD With Code
Jeff_M
I'm on vacation with no way to test/verify @norman.yuan but when you have an Xref or a block of a drawing with Networks, the GetNetworkIds() finds the nested networks. So when you copy/paste there is likely a temporary block created which holds the second phantom network which C3D cleans up when closing the drawing.
norman.yuan
@Jeff_M
There is no block/Xref involved. After running this with a quite large drawing during code debugging, I also thought that, maybe, the copying brought into some "garbage". So, I started a blank drawing, drawing a simple polyline, convert it into a pipe (thus a Network is created). Then I copy this simple pipe into another blank drawing (so, no blockreference/Xref involved). Ran code with GetNetworkIds(), it returned 2 network IDs (i.e. 2 identical Network objects with different ObjectId). Closing and reopening the drawing would get rid of the duplicate.
Norman Yuan
Drive CAD With Code
Kyle-L
I can confirm I am seeing the same issue. I followed your steps and was able to reproduce the results. If I look at Project Explorer after pasting a pipe I also see a duplicated network that disappears after closing and opening the drawing. I also found the duplicated network in the profile view properties pipe networks tab.
This leads me to believe it is a Civil 3D bug and not just an API bug.
