Point Creation Parameters
Message 1 of 8
Hi, Does anyone know how to edit the point creation parameters in lisp, more specifically Prompt for elevations, prompt for point names, prompt for descriptions, default elevation and default description.??? I'd like to change these parameters occasionally depending on what Program I'm running. Thanks in advance.
Replies (7)
Message 2 of 8
Jeff_M
Sure:
(setq c3d (getaeccapp "Land"));;previously posted this function
(setq c3ddoc (vlax-get c3d 'activedocument))
(setq settings (vlax-get c3ddoc 'settings)
      ptcmdsettings (vlax-get settings 'pointcommandssettings)
      createptsettings (vlax-get ptcmdsettings 'createpointssettings)
      ptcreationsettings (vlax-get createptsettings 'pointcreationsettings))
(setq descprompt (vlax-get ptcreationsettings 'promptfordescriptions)
      elevprompt (vlax-get ptcreationsettings 'promptforelevation)
      descdefault (vlax-get ptcreationsettings 'defaultdescription)
      elevdefault (vlax-get ptcreationsettings 'defaultelevation)
;;promptfordescriptions and promptforelevation values
;; 0 = Automatic
;; 1 = Automatic-Object (not used for elevation)
;; 2 = Manual
;; 3 = None
;;example to set any of these settings:
(vlax-put descprompt 'value 0)
Message 3 of 8
Thanks for the code I always do try and search for this kind of stuff before I ask for help. So this is my program so far.
(vl-load-com)
(defun c:cc (/ ent1 oldlay c3d c3ddoc settings ptcmdsettings createptsettings ptcreationsettings descprompt elevprompt descdefault elevdefault nameprompt)
nameprompt (vlax-get ptcreationsettings 'promptforpointnames)
(princ "\nPick your Line ... ")
(setq ent1 (car (entsel)))
(setq oldlay (cdr (assoc 8 (entget ent1))))
(vlax-put elevprompt 'value 0)
(vlax-put nameprompt 'value 0)
(vlax-put elevdefault 'value "0")
(vlax-put descdefault 'value oldlay)
(command "-CREATEPOINTMEASUREOBJECT" ********* "" "" "" "50")
Where I have the ******** is where I need to place the line entity that was selected above with entsel. I
I just want to select the line I want then it puts points every 50 feet with elevation of 0 and desc of layer name using create point measure object. Ideally I want to select a bunch of lines on diffrent layers and add point to all of them every 50 feet but the point code desc must be the layer that that line is on.
Thanks in advance
Message 4 of 8
This is what I have so far.
(vl-load-com)
(defun c:cc (/ ent1 oldlay settings ptcmdsettings createptsettings ptcreationsettings descprompt elevprompt descdefault elevdefault nameprompt)
;; 0 = Automatic
;; 2 = Manual
;; 3 = None
(princ "\nSelect your Lines ... ")
(while (setq SS (ssget '((0 . "*line"))))
(setq i -1)
(while (setq pt (vlax-ename->vla-object (ssname SS (setq i (1+ i)))))
(command "-CREATEPOINTMEASUREOBJECT" **** "" "" "" "50" "")
(command "-CREATEPTPLYLNCTRVERTAUTO" **** "")
);end of while
);end of while
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;end of loop here
(vlax-put elevprompt 'value 2)
(vlax-put nameprompt 'value 3)
(vlax-put descprompt 'value 2)
(vlax-put descdefault 'value 3)
Message 5 of 8
Jeff_M
@Anonymous it looks like C3D 'commands' are not defined to allow you to call them from lisp.
(command "_AeccCreatePointMeasureObject " (ssname ss 0) "" "" "" "50" "")
_AeccCreatePointMeasureObject Unknown command "AECCCREATEPOINTMEASUREOBJECT ".
So create your own tool to add points along an object at the specified interval. Something like this:
(defun c:createpointsoncurve
       (/ c3d C3DDOC COGOPT CRV DIST I LEN OLDLAY PNTS PT SS)
  (setq pnts (vlax-get c3ddoc 'points))
  (setq dist 50.0);;edit this or add a (getdist) prompt here
    (setq i -1)
    (while (setq ent (ssname SS (setq i (1+ i))))
      (setq crv (vlax-ename->vla-object ent)
	    oldlay (vla-get-layer crv))
      (setq len (* -1 dist))
      (while
	(< (setq len (+ len dist))
	   (vlax-curve-getdistatpoint crv (vlax-curve-getendpoint crv))
	 (setq pt     (vlax-curve-getpointatdist crv len)
	       cogopt (vlax-invoke pnts 'add pt)
	 (vlax-put cogopt 'rawdescription oldlay)
  (princ)
Message 6 of 8
Hey Jeff, yes I had thought about that concept of just doing my own without using that cumbersome measure point feature. This code works great, now if I wanted to also add a single point at the end of each polyline as well to define the polyline from start to finish would I just createpointmanual or vlax-curve-getendpoint somehow???
Message 7 of 8
Jeff_M
Sorry, @Anonymous , I was out of town for a few days. Yes, to add the point at the end of the polyline just do so after the (while (< len ...) loop ends.
      	 (setq pt     (vlax-curve-getendpoint crv)
Message 8 of 8
Thanks Jeff I figured it was something easy to add on.
