plot styles
plot styles
plot styles
Are there .ctb files that correlate with the NCS standard templates supplied out of the box? Lineweights are bad thicknesses when I plot a profile for example. I don't want to have to go through & create a new .ctb if there are some provided that go along with the templates provided.
Thanks a bunch.
D.
Did you ever find any ctb files to go along with the templates? This is kind of a tease only giving the templates without the plot styles.
Matt.Anderson
You could always use any of the supplied ctb styles -
Acad.ctb, Autodesk-Mono, Autodesk-Color, DWF Virtual, Fill, Grayscale, etc, etc.
With NCS v4 coming out - I HOPE, named plot styles becomes the default.
Matthew Anderson, PE
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
