- Mute
- Permalink
- Report
I am working on a custom tool in Civil 3D, and I'm encountering an issue when creating a pipe programmatically. After the pipe is created, I am trying to access the Pipe Family ID (using pipe.PartFamilyId), but it returns ObjectId.Null rather than a valid ID.
I even Used the Snoop command in the DWG file to check the pipe's properties, and the Pipe Family ID is still ObjectId.Null.
You will find the code i used below.
I checked parameters.PartFamily to make sure I got the correct ID, and it's correct. However, the Pipe Family ID is still returning ObjectId.Null after creating the pipe.
public class PipesService
public static ObjectId AddLinePipe(Document document, ObjectId networkId, Point3d startPoint, Point3d endPoint, PipeCreationParameters parameters)
var pipeId = ObjectId.Null;
var lineSegment3D = new LineSegment3d(startPoint, endPoint);
using (Transaction transaction = document.TransactionManager.StartTransaction())
var network = networkId.GetObject(OpenMode.ForWrite) as Network;
network.AddLinePipe(parameters.PartFamily, parameters.PartSize, lineSegment3D, ref pipeId, true);
transaction.Commit();
return pipeId;
public static ObjectId AddCurvePipe(Document document, ObjectId networkId, CircularArc3d circularArc3D, PipeCreationParameters parameters)
var endDirection3D = circularArc3D.GetTangent(circularArc3D.EndPoint).Direction;
var endDirection = new Vector2d(endDirection3D.X, endDirection3D.Y).Negate();
PipeCurveGeometry pipeCurveGeometry = new PipeCurveGeometry(circularArc3D.StartPoint, circularArc3D.EndPoint, endDirection);
pipeId = network.AddCurvePipe(parameters.PartFamily, parameters.PartSize, pipeCurveGeometry, true);
return pipeId;
