OSNAPZ Button
OSNAPZ Button
OSNAPZ Button
Hi
I just started using C3D2011 and couldn't find the replace z-value button I used to have in C3D2008.
I tried appload -> AecProject.arx wich used to bring up the button in the lower right hand corner in 2008
but nothing happened.
Any ideas?
Thanks!
Sinc
You could always just create a macro that toggles OSNAPZ, then put it in a toolbar.
Sinc
andrewpuller3811
try this thread http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Z-elevation-taskbar/td-p/2272234
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
AllenJessup
As I mentioned in the referenced post. I created a macro on a tool palette containing (setvar "OSNAPZ" (if (= (getvar "OSNAPZ") 1)0 1)).
Allen
Allen Jessup
CAD Manager - Designer
Thank You for the help, I'm going to use the lisp from the other thread.
