Modifying Child Label Styles
cfindlay5AYZC
Message 1 of 9
cfindlay5AYZC
Our company makes use of many Parent and  Child label styles.
I would like the user to be able to select a label, read its name, and swap it for a label with a slightly different name. This would be an individual change only.
Retrieving the  'LabelStyle is easy enough ... but it doesn't like it if I try to swap it out for my desired label using ... (vlax-put-property repv 'Labelstyle newrepname) ... it only works if the new label is a Parent label ...
if the name that gets passed to it is a Child Label it cannot be found and I get ... error: Automation Error. The parameter is incorrect
Is there a difference between a Parent 'Labelstyle and a Child 'Labelstyle ...
Colin (not a .NET guy)
Replies (8)
Message 2 of 9
hosneyalaa
Is there
a code you are working on
that would be better?
Message 3 of 9
cfindlay5AYZC
We have a left hand surface spot elevation child label and a corresponding right hand surface spot elevation child label ... basically [L] XXX and [R] XXX.
And we want to swap one for the other without requiring any user input.
Colin
Message 4 of 9
BlackBox_
Hey Colin - can you post a sample drawing?
"How we think determines what we do, and what we do determines what we get."
Sincpac C3D ~ Autodesk Exchange Apps
Message 5 of 9
BlackBox_
@cfindlay5AYZC - give this a try - it's a modification to one of my own LISP routines for this same task (we only use parent styles), so it now prioritizes child styles then falls back on parent styles:
(vl-load-com)
(defun c:FLIP (/ *error* acDoc ss styleName key newStyleName ok)
  (defun *error* (msg)
    (if ss (vla-delete ss))
    (if acDoc (vla-endundomark acDoc))
    (cond ((not msg))                                                   ; Normal exit
          ((member msg '("Function cancelled" "quit / exit abort")))    ; <esc> or (quit)
          ((princ (strcat "\n** Error: " msg " ** ")))                  ; Fatal error, display it
    (princ)
  (if (ssget "_:L" '((0 . "AECC_*_LABEL")))
    (progn
      (vla-startundomark
        (setq acDoc (vla-get-activedocument (vlax-get-acad-object)))
      (vlax-for x (setq ss (vla-get-activeselectionset acDoc))
        (setq key
               (substr
                 (setq styleName (vla-get-name (vlax-get x 'LabelStyle)))
                 1
                 3
        (setq newStyleName
                 (vl-string-subst
                   (if (= key "[L]") "[R]" "[L]")
                   key
                   styleName
        ;; attempt to set child style
        (vlax-for child (vlax-get (vlax-get x 'LabelStyle) 'children)
          (print (vla-get-name child))
          (if (= newStyleName (vla-get-name child))
            (progn
              (vlax-put x 'labelstyle child)
              (setq ok t)
              (prompt
                (strcat "\nChild style \"" newStyleName "\" found. ")
        (if (not ok)
          ;; attempt to set parent style
          (if (vl-catch-all-error-p
                (vl-catch-all-apply
                  'vlax-put
                  (list x
                        'LabelStyle
                        newStyleName
            (prompt (strcat "\n** \"" newStyleName "\" not found ** "))
            (prompt
              (strcat "\nParent style \"" newStyleName "\" found. ")
  (*error* nil)
Message 6 of 9
cfindlay5AYZC
Code looks sexier than mine for sure but it still isn't able to complete the swap.
It can read a child label name, derive the opposite label name, but it cannot replace the old label unless the new label is a parent style. (if the new label name is a child style label it cannot find it and returns an error)
Colin
Message 7 of 9
BlackBox_
Colin
It very much swapped to child styles in my drawings.
As I asked before, can you please post a sample drawing?
Message 8 of 9
BlackBox_
@BlackBox_ wrote:
... can you please post a sample drawing?
Hey @cfindlay5AYZC - just following up with you on this.
Cheers
Message 9 of 9
Jeff_M
@cfindlay5AYZC  I have used code similar to @BlackBox_ and could swap child labelstyles without issue. Note that he uses the actual labelstyle, not the labelstyle name as you were doing. This is likely where the issue is.
