Modify Civil 3D Pipe Style Display Settings with Lisp
alexka
Message 1 of 9
alexka
I'm trying to write a lisp that would change the Pipe Centerline layer and color as shown below.
I tried a vlax-dump-object on the style, but I don't know how to find the correct syntax when the "indexed contents not shown"
Has anyone seen a lisp that accomplishing something similar to this, or does someone know how I can find the correct syntax for the non-vla-objects?
Thanks.
Replies (8)
Message 2 of 9
hippe013
To get an item that is indexed use the following:
(vlax-get-property style1 'DisplayStylePlan i)
***Where "i" is an integer index beginning at zero***
Though I am thinking that what you are trying to do is not possible or "not exposed?". I was doing some testing but I was coming up with invalid pointers.
Message 3 of 9
alexka
Thanks @hippe013. That got me going in the right direction. Below is what I came up with. It modifies the layer and color of the plan pipe centerline display. Color 256 is bylayer.
(defun getpipeapp  (/ c3d verstring prodstring)
 (setq c3d        (strcat "HKEY_LOCAL_MACHINE\\"
                          (if vlax-user-product-key
                           (vlax-user-product-key)
                           (vlax-product-key)))
       c3d        (vl-registry-read c3d "Release")
       verstring  (substr c3d 1 (vl-string-search "." c3d (+ (vl-string-search "." c3d) 1)))
       prodstring (strcat "AeccXUiPipe.AeccPipeApplication." verstring))
 (if (setq c3d (vla-getinterfaceobject (vlax-get-acad-object) prodstring))
  c3d
  nil))
(defun c:WaterPipeStylePlan (/)
(setq style0 (vlax-get (vla-get-activedocument (getpipeapp)) 'pipestyles))
(setq style1 (vlax-get-property style0 'item "WATR- N"))
(setq style2 (vlax-get-property style1 'DisplayStylePlan 0))
(vlax-put style2 'color "256")
(vlax-put style2 'layer "C-WATR-PIPE-N")
Thanks again for your help.
Message 4 of 9
jtshumpert
What if you want to select a certain pipe and change that pipe style?
Ex: If pipe style is set to show a proposed style and you want to change it to an existing style.
JTS
Message 5 of 9
alexka
@jtshumpert,
If all you want to do is modify the style of a pipe, you can do that through the properties drop-down given that the pipe style already exists within the drawing as shown below:
I don't think a lisp routine would make this easier. Let me know if I'm not understanding what you're trying to do correctly.
Message 6 of 9
jtshumpert
I Know how to do that, but what to streamline the selection to one button on toolbar, pick one for exist, pick one for proposed...
JTS
Message 7 of 9
BlackBox_
I had to use .NET API to create custom LispFunction for that.
Cheers
"How we think determines what we do, and what we do determines what we get."
Chris Bradley (aka BlackBox)
Managing Partner / Developer / Civil Designer
Quux Software | Sincpac C3D | Style Explorer
Message 8 of 9
Jeff_M
To expand on why @BlackBox_ had to resort to .NET... trying to set the pipe's style in lisp, even though you can successfully get a style to set it to, throws an error. There are 2 ways to try to set a property, (vlax-put pipe 'style newstyle) or (vlax-put-property pipe 'style newstyle) and both throw errors:
error: ActiveX Server returned an error: Bad variable type
error: ActiveX Server returned an error: Type mismatch
Message 9 of 9
BlackBox_
@Jeff_M is correct; for whatever reason, the Style Property for a Part (Structure or Pipe) in LISP is exposed (not listed as read-only), but is clearly not implemented given the exceptions raised as a result of attempting to set that Property.
So, I rolled my own, which allows me to quickly 'sync' any Part (without the lag of synchronizing them all) or to change a Part's Style as I need using this snippet in .NET API (C#):
                            if (styles.Contains(styleName))
                                part.StyleId = styles[styleName];
                            else
                                ed.WriteMessage("\n; error: Style not found ");
Cheers
