Merge hatch lisp
Merge hatch lisp
faisalWJ8Y9
Merge hatch lisp
faisalWJ8Y9
hi All,
trying to use the merge hath lisp routine attached to merge hatches... for some odd reason its deleting the hatches rather than merging them lol.. any ideas as to why?
qchalmersKACEH
I'm using C3D 2026 and agree, unfortunately this LISP doesn't work anymore. It did used to work on older versions of CAD/C3D. Hopefully someone can fix it as it was very useful.
Udo_Huebner
I just checked the above Lisp code in Civil 3D 2026.1 and it works as expected for me:
see short video: https://go.screenpal.com/watch/cTj6QJn2cUh
Perhaps you could upload a sample file with hatches where it does not work as expected. This is not a Civil 3D issue, but rather an Autolisp question and can be better discussed here:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/visual-lisp-autolisp-customizat...
Gruß Udo Hübner (CAD-Huebner)
qchalmersKACEH
You are correct. I was testing it on multiple files which were using solid hatches. With other hatch patterns it does work correctly.
