Listing of Profile Station and Elevation Label
alexisgacia
alexisgacia
Good day.
I'm trying to find the list below but nowhere to be found. Can you point me to the right direction.
I used the code below to search the list of Profile Station and Elevation Label  but failed.
            // Get all the Profile View Styles
            Autodesk.Civil.ApplicationServices.CivilDocument doc = Autodesk.Civil.ApplicationServices.CivilApplication.ActiveDocument;
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            using (Transaction ts = Application.DocumentManager.MdiActiveDocument.Database.TransactionManager.StartTransaction())
                for (int i = 0; i < doc.Styles.ProfileViewStyles.Count; i++)
                    ObjectId oId = doc.Styles.ProfileViewStyles[i];
                    ProfileViewStyle mObjs = oId.GetObject(OpenMode.ForRead) as ProfileViewStyle;
                    System.Diagnostics.Debug.Print("\nProfile View Style Name: " + mObjs.Name + " - " + mObjs.ObjectId);
                //for (int i = 0; i < doc.Styles.ProfileStyles.Count; i++)
                //for (int i = 0; i < doc.Styles.ProjectionStyles.Count; i++)
                //for (int i = 0; i < doc.Styles.LabelStyles.ProfileLabelStyles.MajorStationLabelStyles.Count; i++)
                for (int i = 0; i < doc.Styles.PipeRuleSetStyles.Count; i++)
                    ObjectId PipeRuleSetStyleId = doc.Styles.PipeRuleSetStyles[i];
                    PipeRuleSetStyle mPipeRuleSetStyle = PipeRuleSetStyleId.GetObject(OpenMode.ForRead) as PipeRuleSetStyle;
                    ed.WriteMessage("\nPipe Rule Set Style Name: {0} - {1}", mPipeRuleSetStyle.Name, mPipeRuleSetStyle.ObjectId);
                    //ObjectId profileViewStyleId = doc.Styles.ProfileViewStyles[i];
                    //var o = profileViewStyleId.GetObject(OpenMode.ForRead);
                    //ProfileViewStyle oProfileViewStyle = ts.GetObject(profileViewStyleId, OpenMode.ForRead) as ProfileViewStyle;
                    //ed.WriteMessage("\nProfile View Style Name: {0} - {1}", oProfileViewStyle.Name, oProfileViewStyle.ObjectId);
                    //System.Diagnostics.Debug.Print("\nProfile View Style Name: " + oProfileViewStyle.Name + " - " + oProfileViewStyle.ObjectId);
                ts.Commit();
Many Thanks in advance
hosneyalaa
HI
TRY
LabelStyleCollection lbFVlstyles = civdoc.Styles.LabelStyles.ProfileViewLabelStyles.StationElevationLabelStyles;
alexisgacia
I was trying to find the civilDoc.Styles.LabelStyles.ProfileViewLabelStyles.StationElevationLabelStyles because it was not available, after changing the version of my reference I was able to access it.
Thank you
