lISP to edit survey figure style.
cody.faltin
Message 1 of 12
cody.faltin
I am hoping someone can provide me with assistance in developing a lisp or lisps that would edit survey figure styles.
What I am hoping to accomplish is to select one or more survey figures, and with a single command toggle their status between Flatten to 2D, at 0 elevation, and true 3 dimensional presentation.
I am not finding documentation on how to access the survey figure style through a lisp routine though.
I am not certain that this is even possible with lisp, I have found some documentation that leads me to believe that the portions of the api that reference survey figure styles have not been exposed to lisp, but I'm more a tinkerer with code than and experienced programmer, so I am not sure I am reading the documentation correctly.
I would also be willing to take a stab at it with C#, but my skills there are even more limited.
Thank you,
Accepted solutions (3)
Replies (11)
Message 2 of 12
hosneyalaa
hi
Have you picture explain your idea
Or
Attached example drawing
Any way you need civil API com
Message 3 of 12
cody.faltin
Hosneyalaa,
Essentially I would like to be able to switch the styles between these two states with quick command.
The inspiration for this was a lisp routine I found which will toggle on the display of triangles in a civil 3D surface.  Which is the toggle triangles lisp I have attached.  Using that as a template I am able to get to the point where I can use the code below to select as survey figure, then have it perform an action to change the style.  At this point I am struggling with defining the action.
(vl-load-com)
(defun c:SF2D () (c:SurveyFigure2D))
(defun c:SurveyFigure2D (/ *error* acDoc obj)
(defun *error* (msg)
(if ss
(vla-delete ss)
(if acDoc
(vla-endundomark acDoc)
(cond ((not msg)) ; Normal exit
((member msg '("Function cancelled" "quit / exit abort"))) ; <esc> or (quit)
((princ (strcat "\n** Error: " msg " ** "))) ; Fatal error, display it
(princ)
(if (ssget '((0 . "AECC_SVFIGURE*")))
; need code to change survey figure style from 3D to 2D here.
; Original surface style change is commented out below.
;(progn
; (vla-startundomark
; (setq acDoc (vla-get-activedocument (vlax-get-acad-object)))
; (vlax-for x (setq ss (vla-get-activeselectionset acDoc))
; (vlax-put
; (setq obj
; (vlax-get (vlax-get (vlax-get x 'style) 'trianglestyle)
; 'displaystyleplan
; 'visible
; (1- (abs (vlax-get obj 'visible)))
(*error* nil)
Thank you again.
Message 4 of 12
hosneyalaa
 Hi
As far as I know Style cannot be affected through Lisp It must be through .net
May i make a try through Lisp
https://help.autodesk.com/view/CIV3D/2022/ENU/?guid=780a165a-d1e7-0c12-10e7-44803e78e973
Message 5 of 12
cody.faltin
I had very much suspected that it may not be accessible through lisp.  Looks like I am going to have to dive into C# to accomplish this.  The reference you posted looks like it has a lot of the information I was missing.
Thank you,
I'm going to keep this open for a little bit, just in case anyone else has any good input, but thank you very very much.  Now I just have to learn more about C#.
Message 6 of 12
rl_jackson
My workflow has a process where I import 3D figures into a drawing for surface creation. Then I have another drawing that has the figures for 2D plan data. Here I generally convert the figures to 2d polylines to minimize file size, and the surface drawing is data referenced into the 2D file.
Rick Jackson
Survey CAD Technician VI
Message 7 of 12
hosneyalaa
@cody.faltin
After you get an idea  About C Sharp & CIVIL 3D API
CAN be used  this  CODE With some changes
///  https://forums.autodesk.com/t5/civil-3d-customization/how-to-change-style-of-parcel/m-p/10233647
 var doc = Application.DocumentManager.CurrentDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var civdoc = CivilApplication.ActiveDocument;
            var styleId = civdoc.Styles.ParcelStyles["Lot"];
            var entOpts = new PromptEntityOptions("\nSelect Parcel");
            entOpts.SetRejectMessage("...not a parcel, try again!");
            entOpts.AddAllowedClass(typeof(Parcel), true);
            var sel = ed.GetEntity(entOpts);
            if (sel.Status != PromptStatus.OK)
                return;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                var parcel = (Parcel)tr.GetObject(sel.ObjectId, OpenMode.ForWrite);
                var style = (ParcelStyle)tr.GetObject(styleId, OpenMode.ForRead);
                dynamic oParcel = parcel.AcadObject;
                oParcel.Style = style.AcadObject;
                tr.Commit();
Message 8 of 12
cody.faltin
Thank you so much, between this and a few other tutorials I have followed I feel like I may be able to pull this together.  Once I have I will post the finished code.
Message 9 of 12
cody.faltin
After a fair amount of trial and error and a great deal of searching I was able to put together the following.
At the moment the two methods only apply to the hard coded style of "Test", but I feel confident I can rework it to allow it to function based on a selection.  You will note that several lines are commented as not being necessary, I have left them in place for now as I feel I may be able to use them as a basis for defining the styleID variable based on user selection.  But based on my current understanding they are not actually passing any data to the database.
One thing I have not been able to determine would be how to specify the elevation that figure styles are flattened to. I have located the following reference, but I am unsure of how to implement the get set functionality.
https://help.autodesk.com/view/CIV3D/2022/ENU/?guid=f321bd87-e521-1e82-6471-326b9ed5a896
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.Civil.ApplicationServices;
using Autodesk.Civil.DatabaseServices.Styles;
using Autodesk.Civil.DatabaseServices;
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.AutoCAD.ApplicationServices;
namespace CDF.SFStyles
    public class Commands
        [CommandMethod("SF2D")]
        public void SurveyFigure2D()
            var styleId = civdoc.Styles.SurveyFigureStyles["Test"];
            var entOpts = new PromptEntityOptions("\nSelect SurveyFigure");//These lines are not actually necessary.
            entOpts.SetRejectMessage("...not a survey figure, try again!");//These lines are not actually necessary.
            entOpts.AddAllowedClass(typeof(SurveyFigure), true);           //These lines are not actually necessary.
            var sel = ed.GetEntity(entOpts);                               //These lines are not actually necessary.
            if (sel.Status != PromptStatus.OK)                             //These lines are not actually necessary.
                return;                                                    //These lines are not actually necessary.
                var style = (SurveyFigureStyle)tr.GetObject(styleId, OpenMode.ForWrite);
                style.NetworkDisplayMode = SurveyElevationDisplayType.FlattenElevation;
                tr.Commit();
        [CommandMethod("SF3D")]
        public void SurveyFigure3D()
                style.NetworkDisplayMode = SurveyElevationDisplayType.UseElevation;
                tr.Commit();
This post provided me with the breakthrough for assigning the Elevation display type.
https://forums.autodesk.com/t5/civil-3d-customization/create-survey-figure-style-c/td-p/4882108
Thank you everyone for your assistance.
Message 10 of 12
Jeff_M
To flatten to 0 it should just be:
style.FlattenToElevationBy = 0.0;
Jeff_M, also a frequent Swamper
Message 11 of 12
cody.faltin
Jeff_M, thank you that was exactly what it needed.
Message 12 of 12
cody.faltin
Functional code with a few refinements.  Now loops through a selection set.  Added another method to flatten to a specified elevation.  Also added a regenall to the end of all the methods.
Thank you very much Hosneyalaa, and Jeff_M
            PromptSelectionResult result = SelectFigures();
            if (result.Status == PromptStatus.OK)
                foreach (var objectId in result.Value.GetObjectIds())
                        SurveyFigure figure = (SurveyFigure)tr.GetObject(objectId, OpenMode.ForRead);
                        SurveyFigureStyle figureStyle = (SurveyFigureStyle)tr.GetObject(figure.StyleId, OpenMode.ForRead);
                        dynamic oFigureStyle = figureStyle.AcadObject;
                        var figureStyleName = oFigureStyle.Name;
                        var styleId = civdoc.Styles.SurveyFigureStyles[$"{figureStyleName}"];
                        figureStyle.NetworkDisplayMode = SurveyElevationDisplayType.FlattenElevation;
                        tr.Commit();
                    doc.SendStringToExecute("REGENALL ", true, false, true);
                    Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage($"Flattened to 0'");
        [CommandMethod("SF2Z")]
        public void SurveyFigure2Z()
            var targetZElevIn = ed.GetDouble("\nEnter the desired elevation for flattening survey figures: " );
            var targetZElev = targetZElevIn.Value;
                        figureStyle.FlattenToElevationBy = targetZElev;
                        tr.Commit();
                    Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage($"Flattened to {targetZElev}'");
                        figureStyle.NetworkDisplayMode = SurveyElevationDisplayType.UseElevation;
                        tr.Commit();
                    Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage($"Using true elevations");
        private PromptSelectionResult SelectFigures()
            var options = new PromptSelectionOptions();
            options.MessageForAdding = "Add Survey Figures";
            options.MessageForRemoval = "Remove Survey Figures";
            var filter = new SelectionFilter(new TypedValue[]
                new TypedValue((int)DxfCode.Start, "AECC_SVFIGURE")
            return Application.DocumentManager.MdiActiveDocument.Editor.GetSelection(options, filter);
