Label Components on Separate Layers
DeaconDave
DeaconDave
Has anyone figured out a way to assign separate layers to the different label components?  Is it possible to create blocks with text fields or attributes to call similar data as the Description Keys?  I need to be able to export my finished drawing to AutoCAD and my label components to be on separate layers. I'm currently using Civil 3D 2011.
David King
Civil Designer
C3D 2014 SP2
C3D 2015 SP3
C3D 2018 SP2
Win 7 Pro - 64 Bit OS
Intel Xeon CPU E5-1603 @ 2.80 GHz
8 GB RAM
NVIDIA Quadro 600
DeaconDave
How about in New Expressions....is it possible to push certain components to a specific layer?  Eagle Point allows each label component to be on it's own layer, Civil 3D has to be able to do this.
David King
Civil Designer
C3D 2014 SP2
C3D 2015 SP3
C3D 2018 SP2
8 GB RAM
NVIDIA Quadro 600
Sinc
No, there is no provision in Civil 3D for having individual label components on different layers.
If you have a client that wants old-style point blocks, the best approach is to dump all your Cogo Points out as a CSV file, and let your client import the CSV file into whatever software they are using.
Sinc
Jeff_M
There's also the ConvertPointsToSDSKPoints command (shown as CreateBlocksFromCOGOPoints on the Modify Points Ribbon Tab).
Jeff_M, also a frequent Swamper
Great question...any one....; currently using Civil 3D 2018
