How to 'Project Objects To Profile View' with C# from Modeless Dialog?
tipitasa
tipitasa
How can I use the 'Project Objects To Profile View' command using the Civil 3D API, with C#, to project a selected Solid3d to the selected Profile View from a Modeless Dialog?
The API does not support this call, I followed this https://forums.autodesk.com/t5/net/how-can-i-use-project-objects-to-profile-view-with-c/td-p/1287474... topic to use the Editor.Command();
However, when I try to call this command from the Modeless Dialog, I get an 'Invalid input' exception.
My command uses this flag:
[CommandMethod("DoProjectToProfileView", CommandFlags.UsePickSet)]
This is the relevant code:
// clear the pickfirst set
_ed.SetImpliedSelection(new ObjectId[0]);
// create selection sets
ObjectId[] solidIds = { selectedSolidId };
ObjectId[] profViewIds = { _selectedProfileViewId };
var solidSelectionSet = SelectionSet.FromObjectIds(solidIds);
var profileSelectionSet = SelectionSet.FromObjectIds(profViewIds);
// project
_ed.Command("_.AECCPROJECTOBJECTSTOPROF", solidSelectionSet, "", profileSelectionSet, "");
I tried to surround the Editor.Command with using (_doc.LockDocument()), same as when calling transactions from the Modeless dialog, but it does not help, same exception shows.
If I Close(); the dialog and then try to do the above code, I again get the same exception.
I tried to use the dynamic variable, and got half a result. I can successfully run the command, but cannot set the selection sets.
dynamic doc = _doc.GetAcadDocument();
doc.SendCommand("_.AECCPROJECTOBJECTSTOPROF\r");
// this works as well:
doc.SendCommand("_.AECCPROJECTOBJECTSTOPROF ");
// but none of these do!
            doc.SendCommand("_.AECCPROJECTOBJECTSTOPROF\r", solidSelectionSet, "", profileSelectionSet);
            doc.SendCommand("_.AECCPROJECTOBJECTSTOPROF\r", solidSelectionSet, "", profileSelectionSet, "");
            doc.SendCommand("_.AECCPROJECTOBJECTSTOPROF\r", solidSelectionSet, "\r", profileSelectionSet);
            doc.SendCommand("_.AECCPROJECTOBJECTSTOPROF\r", solidSelectionSet, "\r", profileSelectionSet, "");
            doc.SendCommand("_.AECCPROJECTOBJECTSTOPROF\r", solidSelectionSet, " ", profileSelectionSet);
            doc.SendCommand("_.AECCPROJECTOBJECTSTOPROF\r", solidSelectionSet, " ", profileSelectionSet, "");
            doc.SendCommand("_.AECCPROJECTOBJECTSTOPROF\r", solidSelectionSet, "\r", profileSelectionSet, "\r");
            doc.SendCommand("_.AECCPROJECTOBJECTSTOPROF\r", solidSelectionSet, " ", profileSelectionSet, " ");
What else could I try, or do not understand? Calling the C3D commands is always a heavy guesswork for me, on trying to replicate the C3D workflow.
hippe013
I find that sometimes going over to LISP might help in understanding what arguments a particular method requires.
(princ "\nSelect Solids: ")
(setq ss (ssget '(( 0 . "3DSOLID"))))
(setq ent (car (entsel "\nSelect Profile View: ")))
(command "_.AECCPROJECTOBJECTSTOPROF" ss "" ent "")
The above LISP code will run and then display the dialog for choosing the projection style.
Note that the command is being passed a selection set for the solid's argument, but a single objectID for the profile view argument.
Using VB.NET (sorry, not sorry), I was successful with the following code:
Dim selOpt As New PromptSelectionOptions
selOpt.MessageForAdding = vbCrLf & "Select Solids:"
Dim tvs(0) As TypedValue
tvs.SetValue(New TypedValue(DxfCode.Start, "3DSOLID"), 0)
Dim selFilter As New SelectionFilter(tvs)
Dim selRes As PromptSelectionResult = ed.GetSelection(selOpt, selFilter)
If selRes.Status <> PromptStatus.OK Then Exit Sub
Dim opt As New PromptEntityOptions(vbCrLf & "Select Profile View: ")
opt.SetRejectMessage(vbCrLf & "Selected entity must be a Profile View. Try again.")
opt.AddAllowedClass(GetType(ProfileView), True)
Dim res As PromptEntityResult = ed.GetEntity(opt)
If res.Status <> PromptStatus.OK Then Exit Sub
ed.Command("_.AECCPROJECTOBJECTSTOPROF", selRes.Value, "", res.ObjectId, "")
The dialog box then displays prompting the user to select the projection style.
I hope that this helps!
EDIT - Being that you are invoking your command from a Modeless UI you will want to consider the coding required by a Modeless dialog, some of which you are already aware of, such as Locking the Document. Though, I am not sure if you also need to call the StartUserInteraction method or not.
norman.yuan
The issue is that editor.Command() cannot be used in Application context, which is the context when you start the code execution from an modeless UI. A recent discussion in the .NET forum provides the exact solution yo are looking for:
https://forums.autodesk.com/t5/net/run-a-sample-command-with-parameters-using-c-net/td-p/13334844
Norman Yuan
Drive CAD With Code
tipitasa
Thank you both! I was not truly aware of the changed context in the Modeless Dialog.
I now call the command using the extension method from @ActivistInvestor  from the above linked topic
 https://forums.autodesk.com/t5/net/run-a-sample-command-with-parameters-using-c-net/m-p/13335435/hig...
DocumentCollection docs = Application.DocumentManager;
try
     await docs.CommandAsync("_.AECCPROJECTOBJECTSTOPROF", solidSelectionSet, "", profileSelectionSet, "");
catch (System.Exception ex)
     docs.MdiActiveDocument.Editor.WriteMessage($"Operation failed: {ex.Message}");
