how to create pressurepipe with fitting using c# code
Hi
i want to create  pressure pipe and fittings using c# code  so i am unable to extract pressurepartsize from pressure pipe any one can help me
 Autodesk.Civil.DatabaseServices.Styles.PressurePartSize is showing error that in accessable due to protection level.
oNetwork.AddLinePipe(line,PartSize);
stevenh0616
I've been trying to do a lot of things with the Pressure Pipe API, but it doesn't work. I've been told for a few years now that Pressure Pipes are an emerging component of Civil 3D... and the Pressure Pipe .NET API hasn't been updated since it was first rolled out. Thus, I don't believe this is possible with the current API.
Perhaps others have better input than I do, but that's been from my efforts in trying to get it to work.
Steve Hill, Civil Designer / .NET Developer / AutoCAD and AutoCAD Civil 3D Certified Professional
http://redtransitconsultants.com/
Autodesk Exchange Store
Twitter | LinkedIn | YouTube
March 2019 - any change? - did anyone discover a way to create pressure pipes using the managed api (dot net)?
I guess we could use LANDXML as a work-around.
