how get object id of a line through its label?
mehdi-guida
mehdi-guida
Hi I have the object id of the label. how can I get Object id of the line through label object id?
Norman_Yuan
Assume the label you refer to is C3D label, the the label's property "FeatureId" would be the labelled entity's ObjectId.
Norman Yuan
Drive CAD With Code
mehdi-guida
Thank you so much. It worked .
What about 'line between 2 points label' ?
Is there any Feature Id for virtual line of this type of label?
Do you have any Idea to get start and Ent point of 'line between 2 points label' ?
Thank you
hippe013
You can use the AnchorInfo property of the GeneralSegmentLabel to compute the start and end points.
mehdi-guida
Thank you so much my friends
