How can I calculate the PI of Alignment Spiral?
handgth
Message 1 of 11
handgth
Hello everyone,
I'm working with C3D API to create and modify Civil objects by C# and I want to create Alignment with some curve, spiral.
I want to use this method:
public AlignmentSpiral AddFixedSpiral(
	int previousEntityId,
	Point3d startPoint,
	Point3d spiralPI,
	Point3d endPoint,
	SpiralType definitionType
to create alignment spiral.
But I can not find the Spiral PI.
How can I calculate the PI of spiral when I have start point, end point, length and radius of this spiral?
Please help me.
Thank you.
Replies (10)
Message 2 of 11
essam-salah
@handgth
have you tried using:
AddFixedSpiral(int previousEntityId, double startRadius, double endRadius, double length, SpiralType spiralDefinition)
instead, it doesn't ask for PI.
Message 3 of 11
essam-salah
@handgth
PI is the intersection of the start/end tangents of the curve.
Message 4 of 11
handgth
@essam-salah, Thank you.
I try to use the method
But the application throw the error.
Did I pass something wrong?
Message 5 of 11
handgth
public AlignmentSTS AddFreeSSBetweenCurves(
	int nextEntityId,
	double spRatio,
	SpiralParamType spType,
spRatioType: System.Double
Specifies spiral1 and spiral2 ratio (length or A-value) .
How can I pass the parameter for "spRatio" ( A-value of spiral1 or spiral2)?
Message 6 of 11
essam-salah
@handgth
if you able to post your code it would be helpful.
Message 7 of 11
essam-salah
this error because you passed a station out of the alignment range, try to check any station you pass is lies between alignment start station and end station.
Message 8 of 11
essam-salah
here is the >> Spiral Definitions <<
Message 9 of 11
handgth
In the method
do not have station.
Message 10 of 11
handgth
I want to create an alignment have 8 entities like this :
Line - Clothoid - Arc - Clothoid - Clothoid - Arc - Clothoid - Line.
Message 11 of 11
handgth
I solved my problem by using combination method to create Spiral and method to create STS.
Thanks everyone for the support.
