HELP ME .. 2d Area FOR VOLUME SURFACE USING C#
hosneyalaa
Advisor Advisor
Message 1 of 15
hosneyalaa
Hello all
Please get help 2d Area From volume surface
I GET total cut volume  AND total FILL volume  FROM LINK
http://docs.autodesk.com/CIV3D/2019/ENU/API_Reference_Guide/html/3ccfb05b-56ef-dcfe-d13b-1661a96ccd5...
BUT I AM NEED 2D AREA
HOW  IS THAT PLEASE
http://docs.autodesk.com/CIV3D/2019/ENU/API_Reference_Guide/html/56bd45f8-92ce-c1ac-34d0-b63e46947f7...
// Create the surface
                    ObjectId surfaceId = TinVolumeSurface.Create(surfaceName, baseId, comparisonId);
                    TinVolumeSurface surface = surfaceId.GetObject(OpenMode.ForWrite) as TinVolumeSurface;
                    surface.Rebuild();
 DVG1.Rows.Add(surface.Name, surface., surface.GetVolumeProperties().AdjustedCutVolume.ToString(), surface.GetVolumeProperties().AdjustedFillVolume.ToString());
Accepted solutions (4)
Replies (14)
Message 2 of 15
Jeff_M
That property is not exposed. Nor can we get the triangles to calculate it ourselves.
Message 3 of 15
hosneyalaa
HI @Jeff_M
Do the solution extract the outer Boundare  of the surface as polyline
And calculate its area
Message 4 of 15
Jeff_M
The TinVolumeSurface object does not have the ExtractBorder() method that the TinSurface has.
Message 5 of 15
Civil3DReminders_com
One can create a new TIN surface (temporary) and then paste the TIN Volume Surface into it and then get access to the desired information. This works in a timely manner if the surfaces are not large.
http://docs.autodesk.com/CIV3D/2016/ENU/API_Reference_Guide/html/329508c0-2e0e-5cb6-1279-64666ec5a92...
http://docs.autodesk.com/CIV3D/2016/ENU/API_Reference_Guide/html/2a0de7f5-7b00-1475-e392-ed6ca2d09e0...
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Message 6 of 15
hosneyalaa
@Civil3DReminders_com
Thank you so much
This is Good Idea thank you
Message 7 of 15
gleeuwdrent
You could also use the COM representation of the TinVolumeSurfaceClass. In COM the 2d Area property is exposed:
dynamic comVolumeSurface= volumeSurface.AcadObject; // get the COM representation
double area = comVolumeSurface.Statistics.Area2d;
Message 8 of 15
hosneyalaa
hi @gleeuwdrent
I am a beginner with a language .net
When I put in the code it gave me this image
Is it possible how to write the code completely without a mistake from me
So get the 2d Area
Thanks in advance
                    surface.Rebuild();
 DVG1.Rows.Add(surface.Name, area , surface.GetVolumeProperties().AdjustedCutVolume.ToString(), surface.GetVolumeProperties().AdjustedFillVolume.ToString());
Message 9 of 15
hosneyalaa
Message 10 of 15
gleeuwdrent
Oops, I looked wrong in the API, the mentioned
Statistics.Area2d;
property belongs to TinSurface, not to TinVolumeSurface. Even in COM the 2d area isn't exposed.
You could build a method yourself by iterating trough all the triangles and summarize areas. This link gives you a good starting point.
Message 11 of 15
hosneyalaa
tankyou @gleeuwdrent
Message 12 of 15
Jeff_M
Rather than looping through all of the triangles, just get the Border from the COM object:
            var doc = Application.DocumentManager.MdiActiveDocument;
            var ids = CivilApplication.ActiveDocument.GetSurfaceIds();
            using (Transaction tr = doc.Database.TransactionManager.StartTransaction())
                foreach (ObjectId obj in ids)
                    var surf = tr.GetObject(obj, OpenMode.ForRead) as TinVolumeSurface;
                    if (surf == null || !surf.IsVolumeSurface)
                        continue;
                    var layname = surf.Layer;
                    dynamic volsurf = surf.AcadObject;
                    ObjectId plineId = AcDb.DBObject.FromAcadObject(volsurf.ExtractBorder(1)[0]);//1 is the Plan Display orientation type
                    var pline = (Polyline3d)tr.GetObject(plineId, OpenMode.ForRead);
                    var crv = pline.GetOrthoProjectedCurve(new Plane(new Point3d(0, 0, 0), Vector3d.ZAxis));
                    var area = crv.Area;
                    doc.Editor.WriteMessage("\n{0} area: {1}", surf.Name, area.ToString("F2"));
Message 13 of 15
vucic_tamara
I believe this is the way to get Area2D from TinVolumeSurface object:
tinVolume.GetTerrainProperties().SurfaceArea2D
Message 14 of 15
vucic_tamara
Actually no, there is no such property on TinVolumeSurface, only on TinSurface object. My mistake.
Message 15 of 15
One can create a temporary TIN Surface, paste in the Volume Surface into it, get the property, and then delete the temporary surface. I haven't seen it take a long time for Civil 3D to do, but I haven't tried it on super large surfaces.
Civil Reminders
