Get Turnout Properties
durasovartyom
Advisor Advisor
durasovartyom
Hello Civil 3D community!
Please advise how to extract the properties of switch points.
However, I need to obtain the following properties:
Names of critical points and coordinates (pickets) of critical points.
Perhaps you know how to obtain these properties using Civil 3D API, C#.
I am attaching several examples.
Autodesk Civil 3D 2026 Help | Turnout.GetCriticalPoints Method | Autodesk
How to customize Rail Turnout catalog in Civil 3D
Artyom Durasov
essam-salah
Hi
in order to use
public IList<string> GetCriticalPoints(
	string entryName)
we need to know entryNames  which is not in the documentation
durasovartyom
Dear Autodesk developers!
Please advise how to obtain the entryName of a turnout and all turnout properties via API or Dynamo for Civil 3D.
I would appreciate an example or recommendations on how to obtain:
Critical Points
Geometric parameters (radius, point angle, length, etc.)
Other available turnout properties
Thank you for your help!
Artyom Durasov
hippe013
In the following example 'turnout' is a Turnout object opened for read in a transaction.
Using the following:
Dim criticalPoints As IList(Of String) = turnout.GetCriticalPoints("default")
Returned the following:
CM
CotA_Diverted
CotA_Main
CotB_Diverted
CotB_Main
JP
JT_Diverted
JT_Main
PMA
PRA
Then using this:
  Dim p As Point2d = turnout.GetCriticalPointLocation("default", "CM")
Successfully returned that point.
I hope that this helps get you going in the right direction.
EDIT:
Adding to what I stated above. You can look at the .JSON files provided in:
C:\ProgramData\Autodesk\C3D xxxx\enu\Data\Railway Design Standards\Turnout
You can see the additional available "entries" for a given turnout type.
Single -> "default"
Equilateral -> "default", "left", "right"
Crossing -> "default", "left", "right"
Combined Crossing -> "default", "first", "second"
And so on...
durasovartyom
while task_is_not_working:
    help = get_assistance_from_you()
    if help:
        happiness += 100
        print("Thanks'! You're a genius.!")
        break
Artyom Durasov
durasovartyom
LGTM! (Looks Good To Me)
Thank you for your help. You are a true Senior!
Coffee is on me. Let me know when you are in Lithuania.
Artyom Durasov
