Finding the specific Point
ebo134
ebo134
Hi
I want to know is a point(for example p1) is on the right of an alignment?
can anyone help?!
There is a StationOffset method in the Alignment object which, when fed the northing and easting, will provide, through referenced double variables, the station and offset. If the offset is negative, then you are to the left of the alignment.
HTH,
ebo134
Thank you so much. its exactly what I want
Daniel.Du
If this post answers your question, would you please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Daniel Du
Developer Technical Services
Autodesk Developer Network
