Message 1 of 1
Export the surface to an .xml file using LISP
Hi, I’m trying to automate exporting a surface to an .xml file by creating a LISP function for it. But so far, no success... Can you tell me if this is even possible?
(defun ExportSurfaceToLandXML ( surfaceName saveFolder / C3D verstring prodstring datastr acadApp C3D civilDoc surfs landXMLTools surface filePath )
(vl-load-com)
; Example (ExportSurfaceToLandXML "TIN_example" "C:\\Users\\surfl\\Desktop\\New_folder")
(setq C3D (strcat "HKEY_LOCAL_MACHINE\\"
(if vlax-user-product-key
(vlax-user-product-key)
(vlax-product-key)
C3D (vl-registry-read C3D "Release")
verstring (substr C3D
1
(vl-string-search
C3D
(+ (vl-string-search "." C3D) 1)
prodstring (strcat "AeccXUiLand.AeccApplication." verstring)
(setq datastr (strcat "AeccXLand.AeccTinCreationData." verstring))
(if (and (setq acadApp (vlax-get-acad-object))
(setq C3D (vla-getinterfaceobject acadApp prodstring))
(setq civilDoc (vla-get-activedocument C3D))
(setq surfs (vlax-get civilDoc 'surfaces)))
(progn
(if (not (vlax-property-available-p civilDoc "LandXMLTools"))
(progn
(alert "This is not a Civil 3D document or LandXMLTools are not available!")
(exit)
; Get LandXML tools
(setq landXMLTools (vla-get-LandXMLTools civilDoc))
; Trying to find a surface by name
(setq surface (vl-catch-all-apply
'(lambda ()
(vla-Item (vla-get-Surfaces landXMLTools) surfaceName)
; Checking if the surface is found
(if (vl-catch-all-error-p surface)
(progn
(alert (strcat "Surface with name '" surfaceName "' not found!"))
(exit)
; Create a full path to the file
(setq filePath (strcat saveFolder "\\" surfaceName ".xml"))
; Exporting the surface to LandXML
(vl-catch-all-apply
'(lambda ()
(vla-ExportSurface surface filePath)
; Checking the success of export
(if (vl-catch-all-error-p (vl-catch-all-apply '(lambda () (findfile filePath))))
(alert (strcat "Error exporting surface to file: " filePath))
(alert (strcat "The surface has been successfully exported to file: " filePath))
; Returning the path to the file
filePath
); end of progn
); end of if
); end of defunMost likely, I'm using the wrong Visual LISP functions.
