Explode and Select Window in C#
alexisgacia
Message 1 of 13
alexisgacia
Is it possible to select exploded objects using the select window?
I'm trying to explode and select certain area base on the selected objects. Then those selected object will be save and the rest will be ignored.
Thanks in advance.
Replies (12)
Message 2 of 13
hosneyalaa
Hi
Anther way ,  Example of Explode Region
var region = (Region)tr.GetObject(id, OpenMode.ForWrite, false, true);
                            var objects = new DBObjectCollection();
                            region.Explode(objects);
                            foreach (Entity ent in objects)
Message 3 of 13
alexisgacia
Hi @hosneyalaa ,
Thank you for the reply.
What I mean is like this.
// Here I will select base window mPt1 and mPt2. I tried this but it didnt get the objects from the exploded
PromptSelectionResult mBoxSelect = ed.SelectWindow(mPt1, mPt2);
foreach (ObjectId oInBoxId  in mBoxSelect.Value.GetObjectIds())
Message 4 of 13
hosneyalaa
hi @alexisgacia
my language is not good
Can you share an Autocad drawing?
Explain if you want to reach
Message 5 of 13
alexisgacia
I'm trying to identify the label inside the sheet. Using the boundary of the line, I will able to select the object and Identify the label that I marked. In this case (063, 064, 067, 068, 069)
Message 6 of 13
hosneyalaa
hi @alexisgacia
reading code  from gile
you have to add reference to acdbmgdbrep.dll and Import Autodesk.AutoCAD.BoundaryRepresentation namespace
  https://forums.autodesk.com/t5/net/spatial-query-in-autocad-2010/m-p/5304535/highlight/true#M42041
 [CommandMethod("TEST")]
        public void Test()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            PromptEntityOptions peo = new PromptEntityOptions("\nSelect a polyline: ");
            peo.SetRejectMessage("Only a polyline !");
            peo.AddAllowedClass(typeof(Polyline), true);
            PromptEntityResult per = ed.GetEntity(peo);
            if (per.Status != PromptStatus.OK)
                return;
            using (Transaction tr = db.TransactionManager.StartOpenCloseTransaction())
                Polyline pline = (Polyline)tr.GetObject(per.ObjectId, OpenMode.ForRead);
                if (!pline.Closed)
                    ed.WriteMessage("\nPolyline must be closed.");
                    return;
                DBObjectCollection curves = new DBObjectCollection();
                curves.Add(pline);
                try
                    using (DBObjectCollection regions = Region.CreateFromCurves(curves))
                    using (Region region = (Region)regions[0])
                        PromptPointOptions ppo = new PromptPointOptions("\nPick a point <quit>: ");
                        ppo.AllowNone = true;
                        while (true)
                            PromptPointResult ppr = ed.GetPoint(ppo);
                            if (ppr.Status != PromptStatus.OK)
                                break;
                            Application.ShowAlertDialog(
                                GetPointContainment(region, ppr.Value).ToString());
                catch (System.Exception exn)
                    ed.WriteMessage("\nError: " + exn.Message);
        private PointContainment GetPointContainment(Region region, Point3d point)
            PointContainment result = PointContainment.Outside;
            using (Brep brep = new Brep(region))
                if (brep != null)
                    using (BrepEntity ent = brep.GetPointContainment(point, out result))
                        if (ent is Autodesk.AutoCAD.BoundaryRepresentation.Face)
                            result = PointContainment.Inside;
            return result;
Message 7 of 13
hosneyalaa
OR  can you using
                    TypedValue[] tvs = new TypedValue[]
                        {new TypedValue(0, "text")
                    SelectionFilter filter = new SelectionFilter(tvs);
                    PromptSelectionResult result = ed.SelectCrossingWindow(p1, p2, filter);
                    if (result.Status != PromptStatus.OK) return;
Message 8 of 13
Jeff_M
@alexisgacia The Explode method does not add the objects to the database so selection won't find anything. If you post a small dwg along with the code you are using to the select the region(s) we could probably get this sorted out for you.
Message 9 of 13
hosneyalaa
Message 10 of 13
alexisgacia
Hi @Jeff_M and @hosneyalaa,
Good day.
I attached the DWG File as reference.
User Steps:
Select BlockReference as BlockSheet
Select Target Entities (Circle, Line, Polyline, SPLine)
Desired Output:
Circle (Cyan): 053, 054, 060 & 061
Line(Green): 067
SPLine(Yellow): 056, 057, 061, 062 & 063
Polyline(White): 069, 070, 072, 073 & 074
Block <BlockSheet>: Contains Polyline and Text
Polyline ("A-TITL-TXT2" & "Z_DWG_SHT")
TEST ("Z_DWG_SHT_NO")
My idea on the process:
Explode the BlockSheet to SheetCollection
Remove any objects except objects having layer ("Z_DWG_SHT" & "Z_DWG_SHT_NO")
Loop through to Selected Entities
(SelectCrossing or Alternative function) using boundingbox of the entity as Crv1 to identify the objects in SheetCollection.
(SelectCrossing or Alternative function) Using the boundary of the entity as Sheet having layer "Z_DWG_SHT" from the sheetCollection to check if Crv1 exist in the selection
Once Crv1 exist grab the Text with layer "Z_DWG_SHT_NO"
Currently I don't have an alternative function that can SelectCrossing in the Collection.
Below is the sample code that I did
private void _SelectObjectsFromExploded(object sender, EventArgs e)
            Autodesk.Civil.ApplicationServices.CivilDocument civilDoc = Autodesk.Civil.ApplicationServices.CivilApplication.ActiveDocument;
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            listBox1.Items.Clear();
            string mSheetBlockName = "SheetBlock";
            string mSheetLayerName = "Z_DWG_SHT";
            string mLabelLayerLName = "Z_DWG_SHT_NO";
            cSelection mSel = new cSelection();
            ObjectId mSheetBlockId = mSel.Select_SingeEntity("Select Sheet Block");
            // Set up our selection to only select 2D solids
            var pso = new PromptSelectionOptions();
            pso.MessageForAdding = "\nSelect Curve";
            //var sf = new SelectionFilter(new TypedValue[] { new TypedValue((int)DxfCode.Start, "3DSOLID") });
            //var psr = ed.GetSelection(pso, sf);
            var psr = ed.GetSelection(pso);
            if (psr.Status != PromptStatus.OK) return;
            using (doc.LockDocument())
                DBObjectCollection mSheets = new DBObjectCollection();
                DBObjectCollection mValidSheets = new DBObjectCollection();
                BlockReference oSheet = null;
                doc.TransactionManager.EnableGraphicsFlush(true);
                using (Transaction tr = doc.TransactionManager.StartTransaction())
                    var oBlk = tr.GetObject(mSheetBlockId, OpenMode.ForWrite);
                    if (oBlk is BlockReference)
                        oSheet = oBlk as BlockReference;
                        if (oSheet.Name.ToUpper() != mSheetBlockName.ToUpper())
                            ed.WriteMessage("\nSelected block is not recognize as Block Sheet.");
                            return;
                        // Create Temp Sheets
                        oSheet.Explode(mSheets);
                        mValidSheets = GetValidSheets(tr, mSheets);
                    tr.Commit();
                    if(oSheet != null)
                        foreach (ObjectId oID in psr.Value.GetObjectIds())
                            var o = tr.GetObject(oID, OpenMode.ForRead);
                            if (o is Curve)
                                Curve mCurve = o as Curve;
                                CreateLine(tr, mCurve.GeometricExtents.MinPoint, mCurve.GeometricExtents.MaxPoint);
                                string mSheetCnt = GetSheetNumber(mValidSheets, mCurve);
                                listBox1.Items.Add(mSheetCnt);
                        // Clear Temporary Sheets
                        foreach (Entity ent in mValidSheets)
                            Entity ForDel = tr.GetObject(ent.ObjectId, OpenMode.ForWrite) as Entity;
                            ForDel.Erase();
                    else
                        ed.WriteMessage("\nInvalid Block Selected.");
                    tr.Commit();
        DBObjectCollection GetValidSheets(Transaction tr, DBObjectCollection mSheets, string LayerSheet="Z_DWG_SHT", string LayerSheetNo= "Z_DWG_SHT_NO")
            BlockTable acBlkTbl = tr.GetObject(Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.BlockTableId, OpenMode.ForRead) as BlockTable;
            BlockTableRecord acBlkTblRec = tr.GetObject(acBlkTbl[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
            foreach (Entity oEnt in mSheets)
                if (oEnt.Layer == LayerSheet || oEnt.Layer == LayerSheetNo)
                    mValidSheets.Add(oEnt);
                    acBlkTblRec.AppendEntity(oEnt);
                    tr.AddNewlyCreatedDBObject(oEnt, true);
            return mValidSheets;
                 string GetSheetNumber(DBObjectCollection mSheets, Curve mCurve, string LayerSheet = "Z_DWG_SHT", string LayerSheetNo = "Z_DWG_SHT_NO")
            dynamic acadApp = Application.AcadApplication;
            string mSheetCnt = "";
            PromptSelectionResult mRes = ed.SelectCrossingWindow(mCurve.GeometricExtents.MaxPoint, mCurve.GeometricExtents.MinPoint);
            using (SelectionSet ss = mRes.Value)
                if (ss is null) return "No Selection";
                foreach (ObjectId oId in ss.GetObjectIds())
                    Entity obj = oId.GetObject(OpenMode.ForRead) as Entity;
                    //if (mSheets.Contains(obj))
                    //System.Diagnostics.Debug.Print(obj.GetType().Name + " - " + obj.Layer);
                    listBox1.Items.Add(" - " + obj.GetType().Name + " - " + obj.Layer);
                    if(CollectionHas(mSheets, obj))
                        if (obj.Layer == LayerSheet)    // Sheet Box
                            // Select using box
                            PromptSelectionResult mBoxSelect = ed.SelectCrossingWindow(obj.GeometricExtents.MaxPoint, obj.GeometricExtents.MinPoint);
                            bool HasCurveId = false;
                            bool HasSheetCnt = false;
                            Entity oSheetCnt = null;
                                if (mCurve.ObjectId == oInBoxId) HasCurveId = true;
                                Entity oBoxObj = oInBoxId.GetObject(OpenMode.ForRead) as Entity;
                                if(oBoxObj.Layer == LayerSheetNo)
                                    HasSheetCnt = true;
                                    oSheetCnt = oBoxObj;
                            // If curve and sheetcnt exist add the sheet number
                            if (HasSheetCnt && HasCurveId)
                                if (oSheetCnt is DBText) mSheetCnt = mSheetCnt +", " + ((DBText)oSheetCnt).TextString;
                                if (oSheetCnt is MText) mSheetCnt = mSheetCnt + ", " + ((MText)oSheetCnt).Text;
            return mSheetCnt;
Message 11 of 13
alexisgacia
I changed my code with the new one below.
What I did here is to detect the intersection between Curve and the Sheet, If not check again if Curve.Startpoint is in the Sheet.
                    // Preparing all sheets having valid layers
                            return;
                        mValidSheets = GetValidSheetsOnly(tr, mSheets);
                    // Check all selected Entities
                    if(oSheet != null)
                            if (o is Curve)
                                //CreateLine(tr, mCurve.GeometricExtents.MinPoint, mCurve.GeometricExtents.MaxPoint);
                                string mSheetCnt = GetSheetNumberFromCollection(mValidSheets, mCurve);
                            //Entity ForDel = tr.GetObject(ent.ObjectId, OpenMode.ForWrite) as Entity;
                            //ForDel.Erase();
                            if(!ent.IsDisposed)ent.Dispose();
                    else
                    tr.Commit();
string GetSheetNumberFromCollection(DBObjectCollection mSheets, Curve mCurve, string LayerSheet = "Z_DWG_SHT", string LayerSheetNo = "Z_DWG_SHT_NO")
            // Get Sheets that Intersect the Curve or Containing the Curve
            DBObjectCollection TargetSheets = getIntersectCurveFromCollection(mSheets, mCurve);
            // Select Valid label then check if inside in 1 of the TargetSheets
            foreach(var oTrg in mSheets)
                if(oTrg is DBText || oTrg is MText)
                    Point3d mPosition = new Point3d();
                    bool IsValid = false;
                    string mSheetNo = "";
                    // Check Text Validity
                    if(oTrg is DBText)
                        mPosition = ((DBText)oTrg).Position;
                        if (((DBText)oTrg).Layer == "Z_DWG_SHT_NO") IsValid = true;
                        mSheetNo = ((DBText)oTrg).TextString;
                    else
                        mPosition = ((MText)oTrg).Location;
                        if (((MText)oTrg).Layer == "Z_DWG_SHT_NO") IsValid = true;
                        mSheetNo = ((MText)oTrg).Text;
                    // Check if Inside in 1 of the Sheet
                    foreach(var oSht in TargetSheets)
                        if(oSht is Polyline)
                            Polyline mPL_Sheet = oSht as Polyline;
                            if (mPL_Sheet.Closed)
                                if(IsPointInside(mPosition, mPL_Sheet))
                                    mSheetCnt = mSheetCnt + "," + mSheetNo;
            return mSheetCnt;
        DBObjectCollection getIntersectCurveFromCollection(DBObjectCollection oCol, Curve mCurve, string mValidLayerInCollection = "Z_DWG_SHT")
            DBObjectCollection iSectObjs = new DBObjectCollection();
            foreach(var o in oCol)  // Loop all
                Point3dCollection iPts = new Point3dCollection();
                if(o is Curve)
                    Curve mTrgCrv = o as Curve;
                    if (mTrgCrv.Layer == mValidLayerInCollection)
                        mTrgCrv.IntersectWith(mCurve, Intersect.OnBothOperands, iPts, IntPtr.Zero, IntPtr.Zero);
                        if (iPts.Count > 0) // Detected or intersecting objects
                            iSectObjs.Add(mTrgCrv);
                        else // Not intersecting
                            if (mTrgCrv.Closed && mTrgCrv is Polyline)
                                if(IsPointInside(mCurve.StartPoint, (Polyline)mTrgCrv))
            return iSectObjs;
        private static bool IsPointInside(Point3d point, Polyline pline)
            double tolerance = Tolerance.Global.EqualPoint;
            using (MPolygon mpg = new MPolygon())
                mpg.AppendLoopFromBoundary(pline, true, tolerance);
                return mpg.IsPointInsideMPolygon(point, tolerance).Count == 1;
Message 12 of 13
Jeff_M
@alexisgacia Is the new code doing what you want? I got called away for a family emergency so have not had a chance to look into this further. Your new code is doing pretty much what I was going to attempt. The last step for the text would just loop through the text objects and see if the insertion point is inside the 'selected' sheets.
Message 13 of 13
alexisgacia
Hi @Jeff_M,
Good day.
Sorry for the late reply. It works well for me.
"The last step for the text would just loop through the text objects and see if the insertion point is inside the 'selected' sheets." Yes this is what I did.
Thank you very much.
