- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
... sometimes I use the term Level, sometimes Elevation - my bad, sorry.
Part One (This specific Post / Question)
At our firm, it has always been policy to include Left and Right Road Edge levels in long sections (Profile Views).
To do this with Civil 3D we use Proile from Corridor Feature Line. This method has caused major problems because the resulting Profile is Static and not Dynamic. Problem being: When the source Corridor object is altered and rebuilt, the left and right Profile do not update - designers forget to delete the existing left and right Profiles and forget to create new left and right Profiles.
I have been tasked with making a dev to compare the left and right Profile elevations with the elevations actually used in the Corridor Sections within Section View Group.
I have a suspicion that the corridor section point code levels are not available in the API - correct?
I suspect that the Corridor Section objects get these numbers directly from the Corridor / Assembly - yes?
Part Two (Best Practice for road edge levels)
Maybe our method is incorrect, maybe we should not be making Profiles from Corridor Feature Lines for obtaining road edge levels for long sections.
If there is a better method, then please provide some details.
Thx for reading,
Kevin.
