Edit the GUID of Objects
Denmark.Cunado
Observer Observer
Message 1 of 1
Denmark.Cunado
Observer
Observer
Hi Team.
I had issues regarding the model file that i've done using 3d solid(extrusion etc). I put the object inside the blocks. When im doing some editing, like changing the sizes. The GUID also change . Meaning new object created and this start the problem when exporting it to Navis as most of the object already reviewed and mark as solve. But since it's a new object i will create again a clash issues if it's a true clash. I dont want to remodel it as possible as it takes me a lot of time. what i'm planning to do if it's possible is to edit the GUID.
I'm going to extract the GUID of each object from Naviswork. then Paste it one by one each object in Civil3d.
By the way this are pile footings. i've done it using circle then extrusion and then i added extended data of it.
Any idea that would help me not remodeling it. Thank you in advance
Replies (0)
