Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Edit Properties Palette for 3D Polylines to Display Grade Between Vertices
paul.struch
paul.struch
Hey All,
We have a couple employees who are not entirely proficient with Civil3d given their respective roles. For the most part, I have enlightened them to the power of properties palette and the in-line editing it provides.
I am curious if anyone knows how to edit the tabs/display information of the palette itself. For example, a feature line shows the maximum and minimum grade for a feature line. Is it possible to display, assuming a 3D Poly with only 2 vertices (start/end), a grade between the two vertices in the properties dialog?
I do realize I can access some functionality in the "Quick Properties" of the CUI, however there is not a radio button to add/remove any grade information for the nested properties:
Thanks in Advance!
Jeff_M
The properties palette cannot be modified. PropertySet data may be able to show this, but that's not something I'm up to speed with.
paul.struch
I was afraid that may be the case.  Thanks for the tip; I will need a backup so I will take a dig down the the PropertySet rabbit hole.
Cheers
