dynamic feature line from corridor.
- Mute
- Permalink
- Report
Hi.
I like the dynamic feature line from corridor but it has one limitation.
If there is a curve in corridor, then, the feature line doesn´t have a real arc.
So, I think that Civil 3D should ask us if we want a feature line with real arcs instead of small lines in the curve when we use the command: get "feature line from corridor"
I have to create my own feature line with real arc (to create a grading in one side of corridor) but then it is not dynamic.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
