- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi. I want to use this Event: AcadApp.DocumentManager.DocumentToBeDeactivated += callback_documentToBeDeactivated; In this Event, I want to GetAlignments() from active document, although I get this exception within GetAlignments() method. Autodesk.Civil.ApplicationServices.CivilDocument civDoc = default(Autodesk.Civil.ApplicationServices.CivilDocument); civDoc = Autodesk.Civil.ApplicationServices.CivilApplication.ActiveDocument; //obtener el documento de Civil Debugger throws in "civDoc" line: System.NullReferenceException.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
