Customize Cross Section
erez.m
erez.m
I would appreciate your help with pointing me to the menu where I can turn off the marker at the CL's Insertion point on a section view
My other question is regarding the Section's frame:
I can't see it in layout,
I checked the layers and it's not turned off in any way.
Thank you for your help.
Modify the assembly style,
王磊
您认为此帖子是否有用?欢迎为此帖点赞。
您的问题是否已得到解答?请点击“接受解答”按钮。
erez.m
Thank you for your reply,
I'm still trying to figure out two things about the section Drawing buffer,
1. How to show it on Layout.
2. If there is a possibility to adjust it in a permanent way so it'll be like a frame to the cross section, something like this (i adjusted it manually):
Can you use the axis to form the frame?
not use the dafting buffers.
王磊
您认为此帖子是否有用?欢迎为此帖点赞。
cwr-pae
There is no way to make the drafting buffer print. You can make a border for the profile view through the view style. You can control the size of the drafting buffer under the CreateSectionView node of the Commands branch of the Section View tree.
