Custom Assembly
Custom Assembly
bashardhahir
Custom Assembly
bashardhahir
How can I create assembly like the one shown bellow. I could not find something similar in the tool palates. All the available cross sections has vertical inner side.
Thank you in advance.
alexisgacia
Use Subassembly Composer
Civil3DReminders_com
You can also use .NET to create the subassembly.
It would also be able possible to create a subassembly using polylines and then assign the desired codes.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
cha_javellana
You can create subassembly from polylines.
1. Create polyline of the desired shape.
2. Create assembly from a polyline.
3. Modify origin/insertion point.
4. Edit the file C3DStockSubassemblyScripts found on C:\ProgramData\Autodesk\C3D Version\enu to add new codes. Skip this part if you want to use existing codes.
Reference: https://knowledge.autodesk.com/support/civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Civi...
5. Add codes to the point/link.
6. Add subassembly to assembly.
7. Rebuild corridor.
Here's a quick video showing the process: https://www.youtube.com/watch?v=4YhKLPro7XQ&t=408s
cwr-pae
Use "LaneOutsideSuperLayerVaryingWidth" for the pavement and base to the edge of pavement (grey area and the brown immediately below it), then use "GenericPavementStructure" as the shoulder area (the outer portion of the brown in your sketch). Then use a "LinkMulti" for outer shoulder fill (your blue).
Right click and select help to see how to use the assemblies.
alexis.nunez98YHM
Do you have samples in .Net to create Subassembly from polyline?
nkiakas
This is very easy to be done in SAC.
I have never use the tool to make it from model space with polylines, but i think this subassembly will not be with parameters (widths, etc.).
My recommendation is to use SAC
