Create Parcel Area Table
Message 1 of 8
To workaround the missing API for creating Parcel Area Tables, I have tried the following:
1. Create a "pick point" selection set (using ObjectARX), containing the Parcel for which I want to create a table.
2. Execute the AddParcelTable command.
3. Programmatically push the Select Parcel-button and the OK button of the Create Table dialog using win32 API.
When the Select Parcel button is pressed, the label next to it displays 1 parcel(s) selected and when the OK button is pressed, Civil prompts the user to pick the upper left corner of the table, but the prompt is immediately interrupted with the message "Invalid 2D point" and the table creation is aborted...anyone with a better workaround?
Replies (7)
Message 2 of 8
Hi Rasmus,
I have logged a wish list to expose the necessary API in .NET.
API Wish list ID 1498564 : API to Create Parcel Area Table
If someone else need the same, please add your vote / comment so that I can assign an appropriate priority for this.
Partha
Message 3 of 8
Thanks, Partha! API to create and modify Tables in general would be nice.
Message 4 of 8
Jeff_M
I second this one.
Message 5 of 8
fieldguy
What is the status of this wish list item?
Message 6 of 8
JViljoen
Me too. We need access to all Tables in Civil 3D through the API
www.devotech.co.za
Message 7 of 8
erichermoso5
I am still trying to find a way to create a line/curve table using .NET API instead of using the commands that area available from the Labels and Tables panel on the Annotate Tab. Are there any updates in the Civil 3D API to build a dynamic table with .NET?
Message 8 of 8
Jeff_M
@erichermoso5 not as of C3D 2021. Still just have the basic Properties available.
